I agree with the petcock as a possible suspect, also the kill switch on these can be an issue. Restriction at the petcock should change the sound of the fuel pump.
is it heat related. does the bike run fine cold and then acts up when its warmed? I dont own one but does a guzzi have an ignition coil?
If I have to catch a flight back and find a place to leave the Guzzi for pick up from a shipping company I can do it from there.
Get it to the closest u-haul dealer, rent a one way van. Has to be cheaper than the above.
Rad,I'm an hour ENE of Roanoke (Lynchburg) Have pup & trailer, I can come & pick you & the bike up. Have tools, a few parts & place to work on/store bike if needed. also spare bedroom. Let me know if i can do anything to help, (434)993-3841.ronkom
The power loss is as if the bottle just falls out for a split second and then I can power through it.
TPS is my bet.
Sorry for the late post.... I have been out running the rain.So the thing straightened out for a tank full and now it is back to the same tuff...More later, I just got in to Waterville, no Marriott rooms in Roanoke. Thank you all. Back when I can type on the iPad...
