Author Topic: ecu change  (Read 2722 times)
eweltd
ecu change
« on: July 29, 2015, 04:15:07 PM »
Hi all
Has any one got a 16m ecu from a ducati and swaped it with the 16m ecu in a guzzi and then put the guzzi ephrom or chip in to the ducati 16m ecu if so did it work . see simple .
regards eric
Re: ecu change
« Reply #1 on: July 29, 2015, 04:56:22 PM »
I've never done it, but I'm pretty sure a 16M is a 16M.. Shirley someone that knows will be along shortly. (Subtle bump)
Re: ecu change
« Reply #2 on: July 29, 2015, 06:54:48 PM »
Don't know enough about the 16M but as long as the pin out is the same I can't see any problem.
Offline BMCMOTO
Re: ecu change
« Reply #3 on: July 29, 2015, 07:36:44 PM »
Yes, it will work just fine!
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline Doug McLaren
Re: ecu change
« Reply #4 on: July 29, 2015, 10:42:35 PM »
Got a 16M from a Ducati with a Will Creedon chip in my Sport 1100, works fine.
2019 V85TT
1994 Ducati 900 Monster
1957 Lodola 175
eweltd
Re: ecu change
« Reply #5 on: July 30, 2015, 10:40:46 AM »
Hey Doug
 i have a creedon s2 chip it was in last ecu and could not get rid of flat spot or miss at 3800 rpm now that origonal ecu is f***ed
due to battery fault i am hoping that the problem will go too.
Re: ecu change
« Reply #6 on: July 30, 2015, 11:33:17 AM »
I had a few areas where I'd get flat spots or misfiring and the tickover was very erratic. I made sure the tappets were correct, put in a new Valtec type chain tensioner, new rubber manifolds, tightened exhaust header clamps and did a TPS/TB reset/balance as per the book. It's still not perfect but it's not too far away, I can put up with the odd hiccup as other than that it goes like the clappers.
I also built up a Cliff Jeffries MyEcu to replace the 16M altogether and with that I can experiment with different maps but that's more of a work in progress at the moment.
2019 V85TT
1957 Lodola 175
