Author Topic: Centerstand for a Breva 750  (Read 5882 times)
Offline Jurgen
« on: August 06, 2015, 11:17:11 AM »
Unfortunately I posted this first on the Swapmeet site which was the wrong thing to do.
Can anyone tell me if a centerstand is available for a Breva 750?  If so, where does it mount?  Are there fittings already on the frame?  And how does the bike balance on the C. S.?  My old BMW F650 required 70# of rocks and water in a bucket on the rear rack to lift the front tire.  Lot of good that does on the road if you need to get to the front tube.  Mel replied that I should try Agostino Mandello.  Any other suggestions?
Jurgen
Jurgen
Re: Centerstand for a Breva 750
« Reply #1 on: August 06, 2015, 12:05:20 PM »
Jurgen,
Check with AF1:  http://www.af1racing.com/store/Scripts/prodView.asp?idProduct=53243
Guzzi doesn't balance their centerstands like BMW does.  On Guzzis, the front will be heavy.
« Last Edit: August 06, 2015, 12:12:21 PM by rocker59 »
Offline Jurgen
« Reply #2 on: August 06, 2015, 12:53:49 PM »
Jurgen,
That's the problem with BMW F650, the front is heavy, by about 70#.  So the Breva C.S. balances with the rear wheel in the air?  Jurgen
Jurgen
Offline twhitaker
« Reply #3 on: August 06, 2015, 12:58:37 PM »
I only recently thought to counterweight my bike to make the front end easier to lift. A milk crate loaded with chain on the luggage rack makes the front end easy to lift with one hand while I put a spool under the front of the engine. Works like a charm.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
« Reply #4 on: August 06, 2015, 12:59:47 PM »
Yes.  Rear wheel in the air, but surely not 70-lbs on the front.  Still, you'd need a tiedown or help to remove the front wheel with the Guzzi on its centerstand.
« Reply #5 on: August 06, 2015, 02:56:34 PM »
I just lift the front wheel(easy), put  1 gal. paint can w/2x4 on it under the motor sump and you're good to go.  :wink:
« Last Edit: August 06, 2015, 02:59:53 PM by Arizona Wayne »
Offline sign216
« Reply #6 on: August 07, 2015, 04:25:27 PM »
Jurgen
Jurgen,
I've a centerstand on my 09 V7 and it uses the factory mounts w no problem.  I believe Guzzi is still using the Breva frame for that series, so your should fit without a problem.
The stand is very close to the balance point, so all is good.  I don't think mine is a factory stand, but from one of the major accessory shops (Hepco, etc).
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline ITSec
« Reply #7 on: August 07, 2015, 07:53:53 PM »
I had a centerstand on my 2004 Breva - so I would expect they can be found still.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
« Reply #8 on: August 07, 2015, 10:52:08 PM »
Centerstand is the same for all V7's up to the V7-II and probably that as well but I'm not certain. Baby Breva is same motorbike basically.
« Reply #9 on: August 07, 2015, 10:58:58 PM »
But the Brevas have 17" rims.   Don't all the V7s have 18" rims?
radan2
« Reply #10 on: August 07, 2015, 10:59:40 PM »
I have a centerstand on my Breva 750.  It works very well and is easy to use.  It fitted right on.
« Reply #11 on: August 08, 2015, 03:11:14 AM »
Yes, but the tyre profiles make it an irrelevance.
Offline Hugh Straub
« Reply #12 on: August 08, 2015, 06:32:34 AM »
+1 for AF1
I put a center stand on my 07 Breva 750 following excellent illustrated instructions found by googling "Moto Guzzi Nevada Center Stand Installation" Reportedly, the frames for both Nevada and Breva are the same.  The CS when installed has a slight forward weight bias.
This is an easy job, but note the stand comes with no instructions and some minor filing was necessary to get it to fit.  So have a really good, sharp metal file handy for the job.  Also AF1 will answer questions on the phone to assist you.  Fitting the stand springs takes some thinking...I came up with a solution which made it easy. I think its posted on this site, but send an email if you wish to discuss.
You'll find the stand works easily and well...I never understood how one can enjoy a bike with out a CS.
Brgds
Hugh
"Often wrong, never in doubt"
