Got the parts this week and did the job. All back together again so thought it would start it up. Turned it over with the plugs disconected and then tried with pliugs in.Plenty of power from battery, fuel pump primes, engine tunrns over but no start. Checked plugs -bit wet so fuel getting to them, good strong spark so why no start.Took tank back off to check for anything loose, nothing obvious.What now ?
Well if you check the valve clearances to check for a dramatic change, that should identify a bent valve.
Rollerize part question.The rubber grommet that seals the screws holding on the valve cover changed. The originals on my 2009 were part number 830249 . The roller kit has a different design. But no part number anywhere. They look like they are a better design. More 'squash' to the rubber. The originals are almost not reusable that are so poor.Anyone have a part number for these newer parts?
The c kit for my 09 came with new seals but they looked the same as the originals. I saved the new ones and am still using the old ones.
My originals were cupped on the top. They went on one way. The new ones can go either direction. I assume you have the new ones.
It's unlikely that both sides would be off 360* and that wouldn't explain it popping off the vacuum port cover. I really hope it's something simple but I fear it probably isn't.Also if the owner doesn't know what the vacuum ports are for how was the bike to be tuned after rollerisation? I believe the Norge needs remapping as well? Unlike the flat tappet systems all the roller cams are identical and their characteristics are different from the flat tappet cams.Pete
Hi Pete, i have used Manometer before to tune up, but the nipple has looked more like t brake nipple than anything - this one looks almost surgical.i have just realised something - memory is really crap these days. when the guideline said set the pin to six o'clock i did just that - vertical 6 o'clock - but now think/realise it should have been set to the bottom hole which is more like 5 on the left and 7 on the right ?
