Author Topic: Brake Fluid Change  (Read 7129 times)
Offline tris
Brake Fluid Change
« on: August 13, 2015, 06:41:26 AM »
I'm going to give the bike a treat and change the brake fluid on my 95 Cali.
I have a vac bleeder on the way
Re the linked brakes do I bleed it back to the proportioning valve and then do the 2 callipers or go straight to the calliper bleed nipples?
 Cheers
Tris
1993 TW125 "POS" - Resting
smartin108
Re: Brake Fluid Change
« Reply #1 on: August 13, 2015, 07:09:01 AM »
 :popcorn:
Online Wayne Orwig
« Reply #2 on: August 13, 2015, 07:57:21 AM »
I usually do the entire thing in one shot. Two things.
1) Don't get air in the integrated brake line.
2) The rear caliper bleed screw faces down. You want to remove the caliper and rotate it so the screw is up.
3) Don't get air in the integrated brake line.
Ok, three things.
Oh, and don't get air in that line...... :violent1:
Offline Mike Tashjian
« Reply #3 on: August 13, 2015, 08:04:02 AM »
If you push the caliper pistons all the way in and use wooden wedges to hold them there, Almost all the fluid will be flushed through.  And it gives you a chance to see if they are moving freely.  Mike
Offline Rich A
« Reply #4 on: August 13, 2015, 08:12:34 AM »
You might want to put some kind of penetrant on the bleeder, and use a good wrench to remove it. It can be a pain in the neck when they snap off. You might even want to get a couple of spares to have on hand.
Rich A
Offline toaster404
« Reply #5 on: August 13, 2015, 11:03:26 AM »
Very careful not to get air in master - can be a pain to get it out.  If you end up with bubbles, tap everything that might trap them with a screwdriver handle or equivalent.
Offline lrutt
« Reply #6 on: August 13, 2015, 11:13:09 AM »
1 shot, suck the fluid out of the MC first, or most of it, fill with fresh, then move to caliper. repeat until it's clean out of the caliper, move to next one.
Easy peasy.
Online Perazzimx14
« Reply #7 on: August 13, 2015, 12:13:54 PM »
Check out "reverse bleeding" for your brakes. It works a treat and is much simplier.
Parts needed: 2 syringes and a small section of 1/4"ish tubing.
1. Open MC and suck out as much of the old fluid as possible.
2. Tie brake lever to the handle bar or weight the foot pedel to simulate braking.
3. Fill syringe full of brake fluid
4. Put the proper size box end wrench over the bleed nipple and then connect the brake bleed nipple to the syringe with a small section of tubing.
5. Hold the syringe upright to let the tubing fill with fluid and the air bubble to go up towards the plunger
6. Syringe in 1 hand and while gently depressing the plundger w/ your thumb crack the bleed nipple with your other and inject air free brake fluid into the caliper.
7. When MC gets full close the bleeder and suck out the old fluid in the resi then repeat until clear fluid fills the MC.
The advantage of reverse bleeding is you are pushing any air up to the MC and not trying to suck in downward through the caliper. I bled the linked brakes on my V50 with a Mity Vac and it took hours and pints of fluid to get them properly bled. After rebuilding the calipers and adding SS lines on my T3 I was not looking forward to bleeding the brakes. Then I found out about reverse bleeding and thought what the heck I'll give it a try. In 20 minutes i was cleaning up the tools and admiring a job well done.
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline twhitaker
« Reply #8 on: August 13, 2015, 02:05:15 PM »
www.speedbleeder.co m
My '96 Cali took the SB1010S on all three calipers and they work like a charm. Get the bleed bag too.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline alanp
« Reply #9 on: August 13, 2015, 02:50:39 PM »
This seems like a great way to go, but I have a question.  Why do you say you need 2 syringes?  It seems like you are only using 1?
Niwot, Colorado
'16 V7II Stone - Black
Previous Guzzis
Offline normzone
« Reply #10 on: August 13, 2015, 03:46:55 PM »
Tie tubing around arm, clench fist, slap vein a few times... :evil:
« Last Edit: August 13, 2015, 03:47:20 PM by normzone »
redrider
« Reply #11 on: August 13, 2015, 04:51:28 PM »
I use the HF vacuum bleeder. Piece of pie. It does need an air compressor to function, though.
Regardless of method, a dab of grease on the nipple threads helps sealing. To clean calipers, use a paint stick between the pistons/pucks and give the caliper a shot of compressed air into the caliper where the nipple would be. Remove O-rings and clean underneath with a pick. Easy as cake.
Online Perazzimx14
« Reply #12 on: August 13, 2015, 06:52:20 PM »
One syringe to push in brake fluid and the second for clearing the MC of fluid being pushed into it. You can certainly use one syringe but it takes longer due to switching back and forth from blow to suck.
Offline tris
« Reply #13 on: August 14, 2015, 01:15:32 AM »
Cheers everyone - I guess the key take away is DONT GET AIR IN THE INTEGRATED BRAKE LINE  :grin: :grin:
Offline MilleNut
« Reply #14 on: September 06, 2025, 07:23:13 AM »
 Perazzimx14
I used this excellent guide, and thank you PerrazimX14, to bleed the linked system on my Mille GT. A couple of points for my situation, though.
1) Some advice from others includes detaching and raising the rear caliper above the proportioning valve. This doesn't work for my Mille as it has a solid pipe connection to the caliper.
2) The Mille has a unique proportioning valve. I found that the last operation (to back bleed from proportioning valve down into the master cylinder) didn't seem right. It took a lot of pressure from the syringe until fluid flowed, and it flowed quickly causing a small fountain of fluid to rise out of the m/c. There was only a small improvement to the footbrake linked system. I reversed this last operation and bled up from m/c to proportioning valve - much easier. Perhaps this is a problem for Mille owners. The footbrake was now about 50% better but I needed a break to think about this.
3) I left the system overnight (perhaps I should have fixed the footbrake down to encourage air to rise). Next day, one last crack at the job: I followed the process and found a lot of air in the feed to the front caliper and bled this out. Linked system is OK now.
