anyone lower their pegs on a V7 Classic?
Topic: anyone lower their pegs on a V7 Classic? (Read 4648 times)
DavidV7c
Gosling
August 18, 2015, 10:07:11 AM »
I was just looking and the pegs could come down something between 1 - 2 inches before hitting the pipe. I guess I could custom make the bracket, but the pegs would be fixed with no spring.
Anyone else do this? If so, how, and a picture would be great. Was it necessary to cut and weld the shifter and brake levers, or did you just leave them alone.
THanks
David
sign216
Re: anyone lower their pegs on a V7 Classic?
Reply #1 on:
August 18, 2015, 05:43:08 PM »
David,
I lowered my brake pedal by adding washers to the lever's rear end, so that the brake foot peg would sit lower.
I didn't lower the shift lever, but I did add a new peg, to sit closer to my foot.
I can give you details if you want.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Cam3512
Reply #2 on:
August 18, 2015, 06:22:32 PM »
Todd at GuzziTech sells lower pegs. Think they're one inch lower.
jackson
Reply #3 on:
August 18, 2015, 06:36:33 PM »
Here you go:
http://www.guzzitech.com/store/product/gt-cnc-lower-rubber-top-pegs/
And another choice:
http://www.knightdesignllc.com/Products/Motorcycle/Moto-Guzzi/V7-750/Moto-Guzzi-V7-750-1-Front-Foot-Pegs.html
Last Edit: August 18, 2015, 06:44:08 PM by jackson
NO longer can ride
Reply #4 on:
August 18, 2015, 08:41:12 PM »
Smore here.....
http://wildguzzi.com/forum/index.php?topic=60938.msg930923#msg930923
neverquit
Gosling
Reply #5 on:
August 18, 2015, 09:46:55 PM »
I lowered the pegs on my Nevada by 1 1/2 inches to gain some leg room. I fabricated new mounts from pipe and bar stock. The new ones use the same hinge pins, springs and rubber covers. The only tools needed were a drill, hacksaw, grinder and a welder. The extra leg room is nice but 1 1/2 inches is about all that can be gained because of the brake and shifter position. It was worth the trouble. I've seen some machined from solid stock on Ebay.
Global Moderator
"diplomatico di moto"
Reply #6 on:
August 18, 2015, 09:49:13 PM »
http://www.guzzitech.com/store/product/gt-cnc-vario-adjustable-footpegs/
DavidV7c
Gosling
Reply #7 on:
August 19, 2015, 07:21:08 AM »
Gentlemen,
many thanks. I will get on it this weekend.
Cheers!
