Author Topic: V50 III brKe disc wear limits  (Read 2236 times)
Offline chrisk
« on: August 19, 2015, 01:36:08 PM »
I've just seen the prices of replacement disks so am now thinking I may get mine ground as they are quite pitted.
The Manual says "the thickness of the front and rear disk (new disk) 5.85 to 6.0" but it says nothing about old discs. Do I read this to be 5.85 is the lower limit?
Re: V50 III brKe disc wear limits
« Reply #1 on: August 19, 2015, 01:52:15 PM »
Minimum thickness should be cast into the disc/carrier somewhere.
Offline chrisk
« Reply #2 on: August 21, 2015, 02:36:18 AM »
Had a good look, can't see any writing anywhere...
« Reply #3 on: August 21, 2015, 07:26:34 AM »
I couldn't find wear limits in the shop manuals I looked at.
From EBC
Motorcycle discs have much lower wear tolerances, generally half of one mm each side means the rotor is worn out and should be replaced.
