Author Topic: Mounting 40mm carbs on Le Mans  (Read 2259 times)
Offline Simon_London
« on: August 21, 2015, 04:20:12 PM »
Can I mount 40mm Dellortos on the standard inlet rubbers for Mk 1/2 2 Le Mans 36mm manifolds / rubbers ?
Will this mod work?
Or do the heads need to be ported to accept 40mm manifolds and rubbers?
Will I need to change the slide?
Simon
Offline NCAmother
Re: Mounting 40mm carbs on Le Mans
« Reply #1 on: August 21, 2015, 04:38:50 PM »
I don't know about using the original rubber mounts, I've never used them.  I have Keihin 41mm, with fuel resistant hose to 'stock' intake manifolds. The intake manifolds and heads have been heavily ported and gasket matched.  Doing all the port work , as well as the 'built' motor, required bigger carbs to maximize optimum power/torque.  Is your motor stock?  If so, you should probably stick to the original carb size.
« Last Edit: August 21, 2015, 04:41:45 PM by NCAmother »
Howdy
Online pressureangle
« Reply #2 on: August 21, 2015, 09:52:10 PM »
No, and you don't want 40's on it either. Even on the LM IV, the 40's are cranky and need a light touch below 3500 rpm. On a smaller engine with less compression you'd regret the effort.
