Author Topic: Rode an Electric Motorcycle today. Zero S.  (Read 7716 times)
Doppelgaenger
« on: August 26, 2015, 11:55:02 PM »
After watching a few videos about both the Lightning LS218 and then discovering the Zero S and SR models, I decided to see what is up with these newfangled electric motorcycles.
I went to Triumph of Seattle and test rode the Zero S. What a different experience. What a great experience.
Getting on the Zero is like getting on a large bicycle. Even though it weighs 400 lbs, it feels super light. You also don't see anything but the road in front of you.
Twist the throttle and off you go. It has a slow pickup off the line, which I'm sure is software limited so the bike doesn't loop on you, but once you get above 20 the full power becomes available and this thing just PULLS.  There are no gears, it's direct drive and that means that you have access to full power at ALL times. With a gas bike you'd have to drop two gears and then gas it, with this you just slap the throttle open and you go. The silence is also really nice.
Cons? Full power sucks battery power like crazy and destroys the claimed range. The seat is hard and hurts right behind the testicles, the rear brake is a complete joke. The build quality is meh and there are some strange squeaking sounds when you coast to a stop. The motor can overheat and go into limp mode, but it doesn't actually damage anything.
Most important was the aftermath. I got back on the big Breva and I immediately lamented the loss of that huge torque. "You mean I have to build up the revs before I get full power??" Yeah talk about a poster child for instant gratification.
Go test ride one of these babies, Zero is SUPER responsive as a company. I asked for a demo ride plus to talk to someone from the company about future plans and battery development. they called me almost immediately and sent me an email.
They're still too expensive for what you get, but if their development in the past 3 years is anything to go off of, in 3 more years we'll be buying these like hotcakes and all new riders will be getting one. I'm even tempted to buy one myself.
If you don't believe me, watch this. https://www.youtube.com/watch?v=o3DiAecsh_0
Re: Rode an Electric Motorcycle today. Zero S.
« Reply #1 on: August 27, 2015, 12:41:32 AM »
  Absolutely shocking!
lucydad
« Reply #2 on: August 27, 2015, 05:38:54 AM »
DG,
Revolting?
Pretty cool I think, however it does not burn enough hydrocarbons for my taste...but as a nearly retired geoscientist, what the hell do I care any more?
Offline lucian
« Reply #3 on: August 27, 2015, 06:11:27 AM »
Maybe they could use a little of that dc juice to have a selection  of exhaust notes blared out of a load speaker with volume control.
Offline sarg
« Reply #4 on: August 27, 2015, 06:25:13 AM »
thank christ im 47 and will never be forced to ride an electric motorcycle. ive ridden an electric trials bike. great idea cuz you can ride it almost anywhere for the lack of noise. but just think of life without the vibes between your legs. id rather be dead. rant over
« Reply #5 on: August 27, 2015, 06:34:12 AM »
I have ZERO interest.
Offline O
« Reply #6 on: August 27, 2015, 06:51:32 AM »
Thanks for the report!  Too bad the Livewire isn't getting more push from HD.  That was a great looking electric.  The Zero and Brammo/Polaris not so much.
Owen
2014 V7 Special
« Reply #7 on: August 27, 2015, 07:03:23 AM »
Offline Dilliw
« Reply #8 on: August 27, 2015, 08:17:19 AM »
Jas
Sign me up!!!  A 125 dirt bike that you can ride on the mountain bike trails.  That solves a big problem- places to ride.
George Westbury
Austin, TX
« Reply #9 on: August 27, 2015, 08:19:55 AM »
I'd love to have an electric motorcycle.  Once battery prices get down to reasonable levels I may have to get one.  Getting close.
I got to love electric motors wen working in factories.  Huge torque at 0 rpm.
When the motor is designed right you can even get away with NO drive train.  Just put the motors in the wheel hubs.  Now days the motors aren't much heavier than the bevel drive on a Goose so unsprung weight stays the same.
Offline Johncolleary
« Reply #10 on: August 27, 2015, 08:24:17 AM »
I rode the live wire at the Long Beach motorcycle show last year and was very impressed but the range was way too low to be useable.
2013 Stelvio NTX
2014 Triumph Tiger 800
2024 Honda Transalp
2023 Kawasaki KLX300
Online AJ Huff
« Reply #11 on: August 27, 2015, 08:27:00 AM »
+1. I feel the same way. Just need to hold out a few more years.
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
« Reply #12 on: August 27, 2015, 08:33:46 AM »
taint nobody got time for that!
« Reply #13 on: August 27, 2015, 09:02:22 AM »
Thinking cap on.... Thinking of .... Hybrids.......
Couldn't a regular starter motor be adapted to greatly assist the acceleration of a regular motorcycle when needed?
Whynot? A dual purpose starter motor mechanism that could drive an over-running clutch that is connected to the transmission.
The starter motor weighs alot and is normally not in use other than starting and otherwise has to be carried around all of the time. This is that all it is good for?
 :boozing:
Offline Testarossa
    • Skiing History
« Reply #14 on: August 27, 2015, 09:27:15 AM »
Off-the-shelf starter motor won't work. At 12v it surges to 60 amps when you start cranking, which is barely 1hp; it can run continuously at about 20 amps.
Electric bikes run much higher voltage (Zero uses 102v) and can surge to 40 kW (about 50 hp). That would melt a starter motor in half a second.  Electric drag bikes run more than 350v.
Electric bicycles run 36v to 48v to get up to about 20mph.  My homebuilt electric motorcycle (300 amps max, 20 hp) is geared to top out at 60 mph but at 48v gets only 10 miles range at 30 mph.  Of course I have tiny lead-acid batteries. Within a couple of years Tesla should have the cost of lithium batteries down to an affordable level and I can equip it for a 30 mile range. http://www.evalbum.com/2076
« Last Edit: August 27, 2015, 10:20:01 AM by Testarossa »
« Reply #15 on: August 27, 2015, 09:41:10 AM »
That's always the problem for me and an electric motorcycle.   I don't ride motorcycles in such a way that the present battery technology will support.
Even when I was commuting 60 miles a day, it was marginal.   And now all my rides are longer than that .....
Offline segesta
« Reply #16 on: August 27, 2015, 10:05:02 AM »
I like the idea of riding through a forest trail in near-silence. I'd rather hear birds than my exhaust.
2013 Ducati Monster 796
2010 BMW K1300GT
Offline drums4money
« Reply #17 on: August 27, 2015, 11:18:24 AM »
I rode one of the Empulse bikes a few weeks back and it was a hoot!
That little thing would giddy'up & go.
Key word "little"
Old School Audio:
« Reply #18 on: August 27, 2015, 12:28:59 PM »
Or a recorded deep voice saying ,potato potto potato.
« Reply #19 on: August 27, 2015, 12:37:27 PM »
  :laugh: :laugh: :laugh: :laugh: :laugh:
 OH MY ! For those of you  :laugh:ho think Rocker has no sense of humor ... :grin:
« Reply #20 on: August 27, 2015, 12:38:59 PM »
Jas
That's exactly was I was thinking when I saw it!
« Reply #21 on: August 27, 2015, 12:41:31 PM »
....Just put the motors in the wheel hubs. ....
Which makes making a bike 2WD much easier:
https://www.electricbike.com/ebike-evolution-2wd/
Ever lose traction climbing a muddy trail?   A 2WD electric bike would likely do better!
Offline Yeahoo Whoyah
« Reply #22 on: August 27, 2015, 12:55:25 PM »
According to the Livewire website, there is a demo opportunity tomorrow, August 28, at H-D Asheville North Carolina. I rode one at Sonoma H-D last fall and it was impressive.  I agree with others, the limited range available is a problem.
Greg Tillitson
El Dorado Hills Calif.
Offline atavar
« Reply #23 on: August 27, 2015, 01:07:43 PM »
But without the sound how do you know how fast yur going?   :cool:
« Reply #24 on: August 27, 2015, 01:36:13 PM »
The siren and red lights of the ambulance coming to pick you up.
Offline Robert
« Reply #25 on: August 27, 2015, 01:40:43 PM »
It will come stock with the speaker blaring popping noises on decell.  You have to get it 'remapped' to 'cure' the 'lean' settings.
« Reply #26 on: August 27, 2015, 03:52:50 PM »
Electric dirt bikes would be cool!
More quiet is always good. Electric lawnmowers, weedwackers, leaf blowers and vacuums still make a heck of a racket.
