Changing the rear tire on brothers SP111 and when wheel removed found metal shavings and worn crown gear cover bolt heads. It appears as though the dish shaped flange covering the rubber shock block assy has been touching the bolts as if there was a spacer missing. Anybody ever seen this before?
Best,
Peter
