Author Topic: speedhut tacho  (Read 7504 times)
Offline tris
speedhut tacho
« on: August 31, 2015, 01:43:43 PM »
So - there's been a death in the family The Velia tacho has died  :sad:
Speedhuts offering looks favourite at the moment but if anyone has fitted one to a 95 Cali I'd appreciate some advice
1) which size fits? 3 3/8" looks like it might be too big?
2) can it be triggered from the existing feed
Cheers
Tris
1993 TW125 "POS" - Resting
Rough Edge racing
Re: speedhut tacho
« Reply #1 on: August 31, 2015, 02:11:12 PM »
 I have Speedhut tachs on both a 70 Bonneville and a 97 Harley Buell. The tachs have several signal options built in to accommodate any battery powered  ignition system . They look functional ,have steady needle movement with no delay, are accurate, and are a bang for the buck...However, they are not weatherproof but Speedhut will on order make seal the gauge face. You will have to fabricate a mount. Usually takes about 3 weeks..Made In Utah USA....Go for it... :thumb:
 Speedhut 2-5/8 inch gauge and the stock 3-1/4 speedo
« Last Edit: August 31, 2015, 03:04:26 PM by Rough Edge racing »
Offline bigbikerrick
Re: speedhut tacho
« Reply #2 on: August 31, 2015, 05:04:49 PM »
I have a speedhut tach on my Cal II, works perfect. a couple of fellows here helped me out with the installation, but it was very easy. I even got the moto guzzi logo printed on the face of the tach. I ordered mine in dark blue, but its a bit brighter than the blue on my old cal II, I should have gone with a white face, like some of the older bikes.
Speedhut is a great company to work with.
Rick.
Offline leafman60
Re: speedhut tacho
« Reply #3 on: August 31, 2015, 05:55:45 PM »
I've posted about Speedhut in the past.
I've been using their tachs for a while now. Excellent quality and features.
They offer one of the very few tachs for a single-fire, single cylinder (BMW).
« Last Edit: September 01, 2015, 06:29:12 AM by leafman60 »
Offline Scud
Re: speedhut tacho
« Reply #4 on: August 31, 2015, 08:20:22 PM »
I put 4 Speedhut gauges on my LeMans:
GPS Speedo
Tach
Oil Pressure
Volt
The tach was easy to install and I was able to use the signal wire that fed the ITI unit. Other guys over at the V11LeMans site have also replaced the Veglia with Speedhut.
FYI - you can order the tach with a remote button - or with the button in the glass. I think it is worth the $10 extra for the remote button - you only need it once for setup, then you can disconnect it. Also make sure to tell them it is for a motorcycle and they will give it some extra silicon to make it water-tight.
1989 Moto Guzzi LeMans
2017 Husqvarna 701 Enduro
2017 Moto Guzzi Stelvio NTX
2020 Yamaha TW200
Offline tris
Re: speedhut tacho
« Reply #5 on: September 01, 2015, 12:53:46 AM »
Thanks everyone
Looks like the right solution plus it's about 1/2 the price of a repaired Veglia over here !!!
Measuring day today I think 😁
Re: speedhut tacho
« Reply #6 on: September 01, 2015, 05:25:32 AM »
3-3/8 is the right size, you install it without the rubber grommet that was on the Veglia
Scud's setup is stunning don't you think? Left and right facing eagles even.
Notice his tach is sitting at idle speed, the units use a stepper motor so they stop wherever you turn the power off, use the kill switch and it will go back to zero.
« Last Edit: September 01, 2015, 05:28:25 AM by Kiwi_Roy »
Re: speedhut tacho
« Reply #7 on: September 01, 2015, 07:21:18 AM »
 :1:
Offline tris
Re: speedhut tacho
« Reply #8 on: September 01, 2015, 08:14:21 AM »
KR - I'm a bit puzzled.
The Cali has pods so does the 3 3/8" just slot in and how is it secured in place??
Cheers
PS - yes it is a great install
Re: speedhut tacho
« Reply #9 on: September 01, 2015, 09:44:29 AM »
That's the only tricky part, the Speedhut comes with a large ABS nut that is useless for a bike so you need to make your own arrangement. For my Vll Sport I glued a scrap of aluminium on the back with a stud to poke through the back cover.
I presume you are referring to the chrome EV covers, just make something similar to the Veglia arrangement and space it off the back with a bit of ABS pipe perhaps. The 3-3/8 is a snug fit, it doesn't need much.
What did you do Scud?
« Last Edit: September 01, 2015, 09:54:40 AM by Kiwi_Roy »
Offline Scud
Re: speedhut tacho
« Reply #10 on: September 01, 2015, 11:20:06 PM »
Thanks guys. Kiwi Roy and some other guys over at V11LeMans.com helped a lot.  We had quite a long thread on Installing Speedhut Gauges:
http://www.v11lemans.com/forums/index.php?showtopic=19038
I used some home-electric parts to rig up something that worked with the stock buckets. More details in that link above.
2020 Yamaha TW200
Re: speedhut tacho
« Reply #11 on: September 02, 2015, 05:28:46 AM »
Nice job.. :thumb:
Offline tris
Re: speedhut tacho
« Reply #12 on: September 03, 2015, 09:07:22 AM »
Cheers Scud
That's exactly what I was looking for  :bow: :bow:
Tris
Offline Scud
Re: speedhut tacho
« Reply #13 on: September 03, 2015, 06:18:12 PM »
Glad it helped. FYI - Speedhut puts everything on sale periodically. So if you're not in a hurry, you can watch for one of their sales.
2020 Yamaha TW200
Offline tris
Re: speedhut tacho
« Reply #14 on: September 04, 2015, 11:31:30 AM »
Even Better  :bow: :bow: :bow:
I planed not to do the change out until I park the bike up for the winter and certainly not until after my trip to The Somme Battle Field in November
Watch this space!
Offline mjptexas
Re: speedhut tacho
« Reply #15 on: September 04, 2015, 04:14:42 PM »
I bought a GPS speedometer today on sale at Speed hut!  $30 off.
Mike
'18 R Nine T Urban GS
'17 Griso
'16 XL1200 Roadster
'15 Monster 821
'14 Cali Custom
'14 Vespa GTS300 Super
'15 Vespa Primavera
'75 CB400F
'76 CB550F
Re: speedhut tacho
« Reply #16 on: November 29, 2015, 09:21:00 PM »
First off I will report that Speedhut has 20% off until the 30th for 'Black Friday'
so with that helpful hint out of the way, i do need a little help
Has anyone fitted one of these tachs to a smallblock? I see many have them on v11 powertrain bikes but I assume they plug into the ecu? I have a mechanical pickup.
I have a single pot dash that fits an 80mm veglia  instrument, I am looking to put a combo tach/gps speedo in that hole.
What can you tell me? most of the stuff on their site looks like it is for automotive applications?
Re: speedhut tacho
« Reply #17 on: November 29, 2015, 09:28:49 PM »
You can wire the tach to one of the coils.
Yes they were for automotives but they will add silicone to the glass if you tell them it's for a bike.
I recommend you get the reset button plug at the rear.
Don't forget the Guzzi logo.
« Last Edit: November 29, 2015, 09:34:16 PM by Kiwi_Roy »
