Author Topic: Final drive breather question  (Read 3148 times)
« on: August 31, 2015, 01:58:00 PM »
Is it common that one of these simple devices fail?  Looks like a lot of very fine vapor has made its way onto the inside of my 1200S's swingarm.  No drips on the floor ..... just enough to turn the inside of the swingarm into a sticky dirt catcher.  Of course it could possibly be coming from elsewhere.
Offline Peter from Sch'dy
Re: Final drive breather question
« Reply #1 on: August 31, 2015, 02:24:43 PM »
Hey there,
Seems you must have the CARC off? Have you checked to make sure the pinion nut is not loose?
Best,
Peter
« Reply #2 on: August 31, 2015, 04:10:22 PM »
Prior to 2009 the factory didn't 'Glue' the bevelbox to the swingarm with silastic. The actual seal of the front boot relies on the rectangular clamping plate, (Retained by two small self tapping screws.) crushing the nitrile of the boot between the plate and swingarm to effect a seal that prevents oil escaping into the swingarm.
The thing is it doesn't do it particularly effectively! This means it is quite common for early bikes toget a slight misting around the join, oily deposits in the swingarm and, if the leak is bad, a drip from the rearmost hose clip on the swingarm.
While usually primarily cosmetic, the bevelbox has a breather so it isn't pressurised to 'Force' oil out, it was considered unsightly and worrying by some so in 2009 they started applying great gobs of silastic to the jointing surface before bolting on the bevelbox. This certainly cured the weeps but also makes it an absolute bear of a job to get the bevelbox separated from the swingarm!
What I have done on 'Weepers' is to remove the plate that holds the boot in place and cleaned both boot and mating surface in the bevelbox case carefully with metho or some such volatile and then used a thin smear of threebond between the lip of the boot and the case before re-installing the plate and bolting the bevelbox back onto the swingarm. While it may not prevent weepage as effectively as the litre of silastic used by the factory it does help and doesn't make getting the box off the arm again a completely horrible job!
As mentioned above it could also, possibly, be the pinion seal having let go or the pinion nut having come loose but if the seal goes there is usually lots of oil around the pinion and if the nut has loosened the box will howl like a banshee on the over-run.
I reckon it's just a weepy boot.
Offline toma nova
« Reply #3 on: August 31, 2015, 04:25:01 PM »
Bob,
MPH is chasing a small leak on my CARC and we had the CARC off the swingarm - there was some grease from both u-joints slung inside the swingarm and with Houston temps, some of it was weeping out of the top swingarm clip.
Give the mist a smell (and maybe a taste) - the grease and gear oil are different.
If it's not gear oil, there is no leak.
2014 Stelvio NTX
2008 1200 Sport - sold
« Reply #4 on: August 31, 2015, 04:26:20 PM »
Thanks VDG and Cheese.  I think I'll do the 3Bond fix.  I guess all the goo between the swingarm and final drive on the 2012 Griso is the Guzzi solution,
Bob
« Reply #5 on: August 31, 2015, 04:27:46 PM »
Bob,
Another thing to look at ..... thanks!
Bob
