Author Topic: Durkopp Scooter Tuning (Non-Guzzi Content)  (Read 3319 times)
Offline dgurovich
  • Right Foot Shift is best.
    • As the Dude Abides
« on: September 06, 2015, 08:13:01 PM »
I'm working on a 1957 Durkopp Diana Sport (200cc), with 12v electrics and Electric start.  I've gotten it running and starting under it's own power, and it's frankly an awesome little scoot.
I've got a problem that I'm having a bit of trouble with, as the scoot has a Bing carb.  When it starts the idle will creep up and up until it is very very high.  The bike runs fine, takes off fine, etc, but coming to a stop, the idle just goes through the roof.
I know that 90% of carb problems are electrical, but I think this one is actually a carb problem.  One of the dumbest things that Bing did is make the two jet fittings the exact same size.  I see that one has a screen on it, and the other one doesn't.  I'm assuming that the one with the screen goes under the float bowl?
Any other thoughts about the climbing rpms?  It did not always do this -- it hadn't run in 20 years, and when I got it running it didn't do this.  It all of a sudden started happening, and sometimes the opposite occurred when it would not take a load off idle when in gear.
Thoughts?
Danilo Gurovich
Marine City, MI
  • 1961 Matchless G12 CSR
  • 1966 Matchless G80s
  • 2019 Royal Enfield Interceptor
  • 2006 Vespa 200L
  • 2014 Vespa 300GTV
  • 1968 Moto Guzzi V700
  • 1964 Citroen ID19F Safari (yes, it's a car)
Re: Durkopp Scooter Tuning (Non-Guzzi Content)
« Reply #1 on: September 06, 2015, 09:15:35 PM »
  It's irrevokably broke.  Send it to me and I will dispose of it free.
  BTW do you have the sidecar for it?
« Last Edit: September 06, 2015, 09:25:19 PM by Sasquatch Jim »
« Reply #2 on: September 06, 2015, 09:23:42 PM »
Sounds like a leaky crank seal to me. Sucking in air past one of them and leaning out the mixture.
Offline dgurovich
« Reply #3 on: September 07, 2015, 08:34:35 AM »
I thought about the leaky crank seal, but the idle is very smooth, and it isn't down on power at all when at speed (hauls ass).  It's still on my list.  I think I'm going to pop the carb off and just tighten everything up.
Danilo Gurovich
Marine City, MI
  • 2006 Vespa 200L
  • 2014 Vespa 300GTV
« Reply #4 on: September 07, 2015, 11:00:00 AM »
Is there a good way to test for that?
« Reply #5 on: September 07, 2015, 12:18:04 PM »
Yes .
That's easy for YOU to say ...  :laugh:
I'm just wondering whether this motor is the kind where you can change crank seals from the outside, like an old MZ, or whether it requires splitting the cases .....
Offline dgurovich
« Reply #6 on: September 07, 2015, 03:29:34 PM »
It's a sachs motor.
Danilo Gurovich
Marine City, MI
  • 2006 Vespa 200L
  • 2014 Vespa 300GTV
