Author Topic: My kingdom for an O-ring!  (Read 5414 times)
HoboRob
« on: September 10, 2015, 10:51:46 PM »
The O-ring on my screw-in dipstick is broken on my 2014 V7 Special. I could not find a replacement in the plumbing department or at Canadian Tire.
Can I expect that the O-ring will be sized in metric or imperial?
Where the heck can I find a replacement?
Offline ITSec
Re: My kingdom for an O-ring!
« Reply #1 on: September 10, 2015, 10:59:30 PM »
Good sources for odd o-rings include specialty hardware stores (the kind contractors go to), air conditioning supply houses (HVAC, like building air conditioning systems), and places that make or sell custom hoses (hydraulic, air pressure, etc.).
You didn't mention where in Canada you are, but if you're near a major centre you should be able to find a source. Don't be afraid to call a local HVAC contractor and ask them where they get theirs!
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
« Reply #2 on: September 10, 2015, 11:02:45 PM »
If you must, you can get a larger one and cut a little piece out of it to make it fit proper.
Use a tiny amount crazy glue on one end - the squarer and cleaner the cut the better the results ... practice a bit first ... its EASY!
Offline sib
« Reply #3 on: September 11, 2015, 06:34:00 AM »
Size is 28.24 mm id x 2.62 mm thickness.  If all else fails, the MG part number is GU90706281.  Advice:  wherever you find it, buy two.
« Last Edit: September 11, 2015, 11:03:20 AM by sib »
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline BMWDavid
« Reply #4 on: September 11, 2015, 06:58:17 AM »
You should be able to get one at any NAPA auto parts store.
2002 Moto Guzzi V11 LeMans
2003 Moto Guzzi V11 LeMans
2005 Honda XR650L
2007 Buell XB12Ss
2014 Yamaha FJR 1300es
Southwest Indiana
« Reply #5 on: September 11, 2015, 07:15:27 AM »
Or buy one of these and quit worrying about that stock POS dipstick.
http://pages.ebay.com/link/?nav=item.view&alt=web&id=121220339329&globalID=EBAY-US
You'd be surprised how HOT the oil gets in these bikes.
HoboRob
« Reply #6 on: September 11, 2015, 11:06:04 AM »
Well, I found a replacement! In the Greater Vancouver area: http://www.sealsonline.com
Now, I am just about to place an order for one of those oil temp caps!
What a great forum...
Offline pikipiki
« Reply #7 on: September 11, 2015, 12:59:28 PM »
And how hot is that?
I do like the look of those Dinky guages although thought the purpose was more to tell you when you oil was warmed up. On a Guzzi though I Guess You know that from the feel of the gear shift.
« Last Edit: September 11, 2015, 01:00:22 PM by pikipiki »
Offline Curtis Harper
    • Harpers Moto Guzzi
« Reply #8 on: September 11, 2015, 01:03:31 PM »
CRAZY Idea here, but did you call a dealer?
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
HoboRob
« Reply #9 on: September 11, 2015, 01:17:04 PM »
Yes, I suppose it's odd that I didn't. I would turn to the dealer if I had no luck elsewhere, but I thought my prospects would be better if I just went to an industrial o-ring supplier. I suppose I was afraid that the dealer wouldn't stock such a small item, and that their recourse would be to have an o-ring shipped from Italy!
« Reply #10 on: September 11, 2015, 05:44:44 PM »
 Punch a hole in a piece of old innertube and stretch it over the plug. Screw the plug into the hole.  use a sharp blade to cut away any
 rubber the extends beyond the plug.
HoboRob
« Reply #11 on: September 11, 2015, 05:54:00 PM »
This reminds me of "Zen and the Art of Motorcycle Maintenance", where "John" is horrified at the suggestion that he should use a shim made from a beer can on his fancy BMW. I suppose I fall more into the "beer can / inner tube" camp than the other.
By the way, can you get inner tubes with the MG logo on it? Preferably a gold eagle on a red background? That would be nice...  :grin:
Offline Daleroso
« Reply #12 on: September 11, 2015, 06:19:09 PM »
Just went through my new to me '97 Centauro. Curtis had everything I needed including patience & an always positive tone. Got it to me quick enough. Americans are the only culture that stand in front of a micro-wave & scream "HURRY UP!!!!" I use to train staff to understand that a consumer/patient can go anywhere & get what they wanted. The ONE thing we could control was how we treated them.
Offline lucian
« Reply #13 on: September 11, 2015, 08:51:45 PM »
My daughters v50 still running like a champ thanks to Harpers. :thumb:
« Reply #14 on: September 12, 2015, 06:01:11 AM »
Redline on the thermo is 300*F.  After a decent ride, I check out the temp when I get off the bike.  Usually the needle is in the red.  The thing is made in China, so who knows how well it's calibrated.  All I do know is I don't have to worry about the stick flying out.
« Reply #15 on: September 12, 2015, 07:12:59 AM »
Stick it in some boiling water and you'll have a pretty good idea how accurate it is. You'd rather not know how hot engines run any more.. at least I don't.  :smiley: I just use premium synthetic oil and forget it.
As far as buying an o ring from the dealer? Seriously? My closest dealer is Jim at Rose Farm.. and I doubt he'd want to be bothered to send me something I could go to the hardware and get for 59 cents.
« Reply #16 on: September 12, 2015, 07:23:28 AM »
True. I don't sweat it either.  More often than not this summer, I'm the one that's overheating!
« Last Edit: September 12, 2015, 07:24:03 AM by Cam3512 »
« Reply #17 on: September 12, 2015, 08:55:01 AM »
A few of us Guzzi owners will be heading out for Stave Lake Hydro Museum this morning
Get your act together and join us for World Guzzi Day
"O" rings, Lordco on Kingsway has a good selection on the wall.
Roy
