Author Topic: Startus spontaneous?  (Read 6106 times)
Offline Testarossa
    • Skiing History
« on: September 13, 2015, 06:35:13 PM »
I changed the oil this morning, then hosed off the bugs and road grime collected over the past month. Put the T away in the garage.
A few minutes later Gail runs into the house saying "The Guzzi is trying to start!"  I ran out and found nothing amiss.
"You're hallucinating," I told her.
"No, really, it made that noise as if it's trying to start. I went toward it and it stopped. I walked away and it cranked again."
Well, either Gail is delusional, or some moisture got into the starter solenoid and shorted something, maybe. Has anyone experienced this?  No harm done -- of course the ignition was off.
I need to add that the new starter is a cheap Chinese unit installed after the flood. I haven't got around to cleaning the mud out of the "real" starter.
Re: Startus spontaneous?
« Reply #1 on: September 13, 2015, 06:40:46 PM »
 Considering how far it is from Lafayette LA to Longmont CO , it probably isn't a hoodoo , so yeah probably water somewhere  :laugh:
Offline lucian
« Reply #2 on: September 13, 2015, 06:55:09 PM »
Wow, and most of us worry about startus interuptus. That will teach you to wash your bike.
Offline Yukonica
« Reply #3 on: September 13, 2015, 07:08:18 PM »
Did you post that or did your wife hijack your login?
Offline ITSec
« Reply #4 on: September 13, 2015, 07:13:54 PM »
They have hoodoos in Colorado - it's just that they're eroded formations of soft rock...
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline Guido Valvole
« Reply #5 on: September 13, 2015, 07:16:23 PM »
Girlfriend many years ago had a Yamaha 650, kinda ratty. She paid a friend to clean it up and detail it. I rode in the garage and saw the headlight on, thought she was going somewhere. Strange, no one around, engine's not running, no key, light's kinda bright��um, is that smoke coming out from under the tank?!? Ran inside, woke her up, and we pulled the battery ground asap. The guy who detailed the bike had apparently used a pressure washer, and water got into the main bundled-up part of the wiring harness. Major electrical repairs ensued.
Before heading to the 2008 National Rally in Malibu with a friend, he took a look at my V50 and said he didn't want to ride with someone with a dirty bike. And so we washed it, carefully. Not carefully enough, as it didn't start after that. Thought it was the starter solenoid, which needed a little persuasion by being poked with a stick. Got through the rally that way and later discovered that an electrical lead at the front of the engine had been knocked loose. back on it went, dielectric grease around that to keep moisture at bay, and started right up.
I keep hoses well away from my motorcycles! Electrons and water are a bad combination.
cr
V50 II
V50 Monza
Le Mans 1000 (IV)
Martinez, CA
Offline lucian
« Reply #6 on: September 13, 2015, 07:42:32 PM »
I ride in the rain a lot and it never caused any problems. I washed my griso once with a hose, paying extra attention to the rear drive as it was very gritty. I did not want grit working it's way into the carc seals so I cleaned it up real nice. I'll be damned if the most important part of the bike  didn't stop working for three days, the speedometer.  :angry: I have since sealed the speedo sensor, but no more hose.
Offline SeanF
« Reply #7 on: September 13, 2015, 07:45:10 PM »
I had that happen on my T. An interesting moment, to say the least.
It was the result of one of the harnesses going into the headlight shell having become loose & grounding against the bucket.
« Reply #8 on: September 13, 2015, 08:10:27 PM »
It's water and dirt combination that conducts electricity.
Clean water barely conducts, wet dirt does.
I pressure wash my bikes all the time and the car gets a a good HP wash under the hood, so far I have had no problem.
« Reply #9 on: September 13, 2015, 08:18:30 PM »
 So... Roy , are you saying that washing one's MC with muddy water is a bad idea  :huh: :laugh: But yes , distilled water will barely conduct 'lectricity .
« Reply #10 on: September 13, 2015, 08:45:24 PM »
  Queer electrons blow fuses.
Offline lucian
« Reply #11 on: September 13, 2015, 08:55:57 PM »
Damn, I peed my pants again. :laugh:
Offline ITSec
« Reply #12 on: September 13, 2015, 09:02:35 PM »
Jim, you're getting confused on your particle physics. Electrons are negative, and create a bad attitude.
Quarks, on the other hand, can be queer - or charmed, strange, top, bottom, up or down. Of course, this may be a one-dimensional perspective, in which case I'd be stringing you along...  :boozing:
ITSecurity
« Reply #13 on: September 13, 2015, 09:33:33 PM »
 Two neutrons walk into a bar , the bartender sighs and says ... well , you know  :laugh:
 And then you have those 1/2 spin thingies  :huh:
Offline Testarossa
    • Skiing History
« Reply #14 on: September 13, 2015, 09:59:10 PM »
"Shit, I lost an electron."
"Are you sure?"
"I'm positive."
Offline Farmer Dan
« Reply #15 on: September 13, 2015, 10:23:45 PM »
Thanks Jim, I needed a good laugh.
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
Offline Testarossa
    • Skiing History
« Reply #16 on: September 14, 2015, 05:59:57 PM »
The spontaneous cranking was the death rattle of the starter solenoid, which won't even click today. Will clean out the Bosch in the morning, and if I can't get it to work will order a Valeo from EME.
Offline atavar
« Reply #17 on: September 14, 2015, 06:23:20 PM »
I have heard of two versions of startus spontaneous.  On one it is as you described and after washing the starter relay engages and the engine cranks.
On the other - which is scarier - with old cdi ignitions some bikes that hold compression have been known to start without the starter when you turn the ignition on or take off the kill switch.  Apparently the old electronic ignitions emitted a spurious spark when first engaged, and if you were lucky enough to have one piston just past tdc with a rich mix in the cylinder it goes bang and bobs yur uncle.  i always thought that could be a handy feature if a guy could perfect and patent it..
I actually had this happen a couple times on my old G5, so don't try and tell me it can't happen.
Offcamber1
« Reply #18 on: September 14, 2015, 06:27:36 PM »
real men push start their bikes!
Offline Testarossa
    • Skiing History
« Reply #19 on: September 15, 2015, 01:27:29 PM »
I've bump-started the T often enough.
This time it's not the starter solenoid -- just the starter relay, probably in service 20 years. It clicked, but no continuity across the high-amp terminals. I'm guessing it arced itself to death.  50-cent replacement and we're back in business.
