Getting fork oil in on LM 3. ?
Topic: Getting fork oil in on LM 3. ? (Read 3525 times)
dsrdave
September 16, 2015, 05:02:09 PM »
Anyone know a good way to get the atf into the forks on a lemans 3 with the air shocks ? Forks are on the bike. Thx, Dave.
2-850T, 2-1000 convert/hacked, V11 sport, V50, centauro, '97 sport 1100, '71 V7 ambo, '76 850 Lemans,CX100,"83 LM III,1000SE, '91 LM V, '07 Griso, '53 super alce,moto parilla, zigolo, Lodola 175,and 235, '07 norge, '67 stornello, 57galletto, Nuovo Falcone, 66 ISDT, 52 Airone sport, cafe sport
Re: Getting fork oil in on LM 3. ?
Reply #1 on:
September 16, 2015, 05:14:57 PM »
Support bike under sump, remove front wheel and mudguard so forks can be stroked independently, undo dampers from top of legs, drain fork by removing plug but don't move the fork while the plug is out, reinstall drain screw, push slider up and damper will slide up out of leg, get syringe and dribble oil slowly down damper. When oil tries to spill out of leg pull slider down until you hear fork gurgle air, then slowly lift it again and repeat until you have added the required amount of oil. Screw damper back into leg.
Repeat for other leg.
Alternatively take the forks to pieces and give them a proper seeing to and cleaning. They're older than dirt and probably have oysters living in them!
Reply #2 on:
September 16, 2015, 05:17:46 PM »
"Oylsters?"
kidneb
Reply #3 on:
September 16, 2015, 06:10:46 PM »
I never remove the front wheel if I just want to change the fork oil. Just put the bike on the center stand and drain both legs, pressing the forks down helps to get all the oil out.
Then do one leg at a time (don`t loosen both caps at the same time !!
) Now, with the front resting on one leg, the bikes weight will press the loose cap up to allow for the oil filling.
May not be the "right" way, but works for me.
//Ben
Last Edit: September 16, 2015, 06:14:06 PM by kidneb
Chuck in Indiana
Reply #4 on:
September 16, 2015, 07:08:24 PM »
Just documented this in the Lario rehab thread.. page 19
http://wildguzzi.com/forum/index.php?topic=58695.540
dsrdave
Reply #5 on:
September 16, 2015, 07:21:28 PM »
Thanks for the help guys. I was not sure if the air stuff made any difference. Dave.
SED
Reply #6 on:
September 18, 2015, 12:11:45 AM »
Another, quicker way to do it:
Put a block under the sump and unscrew the damper caps from the fork legs (bike sits on block). Pull one drain screw and drain old oil (if any) then get a big syringe. 60mL syringes (maybe larger) are available at farm stores. Fit a thick o-ring or a small piece of rubber hose over the nipple.
Fill the syringe with ATF and inject the ATF in the drain hole. Pull the syringe out and quickly reinsert the drain screw. A little ATF will leak out but not much. Repeat until you have the volume you want. It's just to lube the sliding parts so exact volume is not critical and if careful you will be within a few mL. Much quicker than dribbling down under the damper cap - probably save more than 1/2 an hour standing around.
Tighten the dampers back down and you're done.
More here (it's a Monza but I've got an LMIII also and it is the same but larger):
http://wildguzzi.com/forum/index.php?topic=75441.30
Hope this helps.
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
