Author Topic: R/R Engine Temp Sensor holder on a Ballabio  (Read 5081 times)
Offline Stormtruck2
  • AKA Scotch and Cigars
  • Geese Fly in a Proper V
« on: September 16, 2015, 10:46:49 PM »
Temp sensor has come clean out of the holder on the Billy Bob.  I have a new brass holder to install, but how to get the old one out.  I searched V-11 Lemans and here and found nothing useful, probably a search failure on my part.   Billy Bob is udders up until I get it replaced.  Since I will be having some free time for a while here, I may as well get on it, upon my return from Mo-Kan.  :boozing: :thewife: :thumb:
« Last Edit: September 16, 2015, 10:47:10 PM by Stormtruck2 »
μολὼν λαβέ-molṑn labé
Re: R/R Engine Temp Sensor holder on a Ballabio
« Reply #1 on: September 16, 2015, 11:04:29 PM »
Unscrew it?
Offline Stormtruck2
« Reply #2 on: September 16, 2015, 11:12:25 PM »
Unscrew it?
Doesn't seem to have any place to put a wrench on it. All I have is a piece of copper sticking out.
« Reply #3 on: September 16, 2015, 11:52:06 PM »
Can you post a pic?  I'm not getting a visual from that description.
« Reply #4 on: September 17, 2015, 12:10:48 AM »
There actually is a hex nut down in there, but it sits down in the aluminum head a good bit.
There is some trick, like grinding the end of a 17mm deep socket flush, that will grab it and screw it out. I forget exactly how it was.
« Last Edit: September 17, 2015, 12:17:30 AM by Wayne Orwig »
Offline Kent in Upstate NY
« Reply #5 on: September 17, 2015, 12:26:53 AM »
Where did you get the brass holder? Inquiring minds want to know.
« Reply #6 on: September 17, 2015, 06:53:11 AM »
Like Wayne sez, either grind down a socket or drive a big hunker eze out in there and screw it out.
Offline Stormtruck2
« Reply #7 on: September 17, 2015, 07:16:18 AM »
C&D Motorsports AKA Cwiseman here on the forum.
http://www.cdmotorsports.com/location.htm
Offline Bill Owens
« Reply #8 on: September 17, 2015, 08:53:24 AM »
don't know if I was just lucky but what I did was to take a flat file and break of the end of the tong so the remaining part of the tong was wide enough to bite into remaining brass acting as an easy out. With a good strike of the hammer it bit right into the brass and with an adjustable wrench on the file it backed right out
Offline Stormtruck2
« Reply #9 on: September 17, 2015, 11:20:15 AM »
I'm trying to get a better pic of further down inside.  But as a lousy wrench as I am, I'm an even worser :rolleyes: photographer.
« Reply #10 on: September 17, 2015, 11:23:27 AM »
If you want to ride in the meantime slather the old sensor in silicone and jamb it back in,
« Reply #11 on: September 17, 2015, 01:15:46 PM »
Yes, that should unscrew.
Offline twhitaker
« Reply #12 on: September 17, 2015, 01:31:03 PM »
A hammer and a cold chisel or a punch should make short work of it. Once it starts turning it should be free to turn with your fingers.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
« Reply #13 on: September 17, 2015, 01:47:47 PM »
My big problem with the plastic holder was that it never stayed tight.  The other problem was that the location made it difficult to get a wrench on.  I wouldn't be surprised if it was already finger tight.
« Reply #14 on: September 17, 2015, 06:52:22 PM »
I've had a couple of them just crumble into dust when I tried to pull off the connector. Modern miracle space age plastic..  :smiley:
At least the bottom is brass.
