Author Topic: clutch problem still there  (Read 5113 times)
zari
« on: September 17, 2015, 01:50:09 AM »
Hello
After replacing the parts still after several trips I feel that  the. Clutch not separating   smootley and I have to adjust again what could be the cause this time
Maybe  the problem still there ?
Please. Help   :copcar:
zari
Re: clutch problem still there
« Reply #1 on: September 17, 2015, 02:13:09 AM »
If I  ,adj  to have a good separation then I check and see that I had no freeplay of recommended If I keep my freeplay so I do not have good separation.
« Reply #2 on: September 17, 2015, 02:42:31 AM »
Where are you adjusting? And what bike again? Five speed V7 is it not?
zari
« Reply #3 on: September 17, 2015, 09:40:26 AM »
[/quote
  I adj the. Bottom rear adj screw. I have. Navada 750 1994
Recent  post http://wildguzzi.com/forum/index.php?topic=70092.0
« Reply #4 on: September 17, 2015, 12:21:14 PM »
Try re-routing the cable to eliminate tight bends.
zari
« Reply #5 on: September 18, 2015, 07:24:40 AM »
Please tell me by diagram or. Pic the right path (route) for clutch cable
Any way. Thanks
Zari :clock: :bike-037:
Offline Stevex
« Reply #6 on: September 18, 2015, 08:17:50 AM »
Hmm, if you're having problems routing a clutch cable correctly on a Guzzi, I'd step away from the bike and go find a mechanic.
Seriously.
« Reply #7 on: September 18, 2015, 01:53:56 PM »
Any way. Thanks
Zari, I'm sorry but I don't have a Nevada handy to show you. Simple explanation? Route it as directly as you can without tight bends or kinks. The outer cable is wound in a spiral. If you put tight bends in it the coils of the spiral spread apart in the bends. When you pull the lever the force and travel of the inner cable is used compressing the spread coils back together rather than giving travel to pull the arm and engage the clutch. Gentle bends = less spreading of the coils and greater travel of the inner cable.
zari
« Reply #8 on: September 18, 2015, 05:14:53 PM »
Another problem I noticed is leaking transmission fluid from the area of ​​the connection between the foot lever to the motor  I saw that they have some freeplay   in axis what could be the reason? And do I have to open the area of the. Gear? :bike-037:
zari
« Reply #9 on: September 26, 2015, 01:06:21 AM »
I was check the crank bearing free play by push and. Pull. The alternator poly  and got. Less then 1mm. This is normal. Are. This test show me the status  of  bearing condition ?
Pic at:https://picasaweb.google.com/117012899164096054821/September262015#6198698816769454610
Online John A
« Reply #10 on: September 26, 2015, 04:37:07 AM »
Your crankshaft end play is just fine then. What new parts did you put in?
« Last Edit: September 26, 2015, 04:38:52 AM by John A »
Orange Guzzi
« Reply #11 on: September 26, 2015, 10:51:06 AM »
Different bike, 2003 1100, but when this happened on my bike, the clutch friction pads were separating from the spline plate and getting jammed between the plates.  I could adjust the clutch, but this allowed a bigger piece to get jammed.   Finally locked up and I rode 120 miles with out a dis engaging clutch.
zari
« Reply #12 on: September 26, 2015, 11:53:30 AM »
Thanks john   I was put all pushrode system  see in this link:https://drive.google.com/file/d/0B4B-yQPVgkcZLXA2U3lkOE12dVk/view?usp=sharing :gotpics: :bike-037:
« Reply #13 on: September 26, 2015, 12:49:37 PM »
Seems there are several issues here.
1)  Mechanical ability of the OP.
2)  Motorcycle mechanical ability.
3)  Language barrier.
4)  Pix posting ability.
Some of the barriers will be hard to overcome.  In short, might be better to take it to a motorcycle mechanic or have a friend that is a mechanic do the work.  Bite the bullet and pay for the work.
