Author Topic: Removing stubborn spark plugs  (Read 7090 times)
Offline guzziownr
« on: September 17, 2015, 10:16:05 AM »
I am parting out an old T-3 that has been sitting outdoors for 20+ years.  The spark plugs are stuck solid and the usual dollops of PB Blaster and applications of the propane torch have left them unmoved.
Before I reach for the breaker bar is their anything else I should try?
DW
Online nc43bsa
Re: Removing stubborn spark plugs
« Reply #1 on: September 17, 2015, 10:34:44 AM »
I could suggest a method if you're not in a hurry;  it takes a few weeks.
1990 MilleGT
Offline clubman
« Reply #2 on: September 17, 2015, 11:01:17 AM »
I've seen pistons that were rusted solid into iron bores broken loose by pouring smoking hot olive oil into the bore. The hot olive oil thins down so much it apparently penetrates well. Don't know if it would work on a plug. Obviously a good opportunity to burn the crap out of yourself, much care.
Gen. 3 Hayabusa,  KTM 890 Duke, Indian  FTR1200R Carbon R, Triumph Speed 400, Triumph 765RS
« Reply #3 on: September 17, 2015, 11:26:47 AM »
Is that you Luigi?
Offline Two Checks
« Reply #4 on: September 17, 2015, 11:28:51 AM »
The spark plug has a metal seal preventing the penetrant fro penetrating. Remove the had and apply penetrant from the end of the plug.
1987 1000 SPII "Il Duce' II"
Offline uncle
« Reply #5 on: September 17, 2015, 11:41:51 AM »
With the heads off you may get better oil penetration from the inside...
You could also heat the heads (to pretty darn hot) then spray the plug with brake cleaner - (never tried it myself, but I like the idea).
Ever onward...
biking sailor
« Reply #6 on: September 17, 2015, 11:57:33 AM »
Remember the formula for top performing penetrating oil, 50% acetone and 50% automatic transmission fluid.
« Reply #7 on: September 17, 2015, 12:16:42 PM »
Some brake cleaners + flame = toxic phosgene gas. I'd be very reluctant to use it even on something that's been heated "to pretty damn hot".
Offline redrider90
« Reply #8 on: September 17, 2015, 12:17:49 PM »
Olive oil oxidizes/smokes at 350 degrees whereas peanut and a few other  oils oxidize at 450 degrees.  I assume olive oil and peanut oil have the same ability to penetrate when heated?
So maybe using an oil that has a higher flash point might work better??? I dunno but with a low flash point I gotta wonder is using an oil with a much higher flash point would work better.
Last time I had trouble with a spark plug was on my old Duc. I went to replace the plugs and turned ever so gently and the thread came right off the head. Ouch.
Red 90 Mille GT
Online John A
« Reply #9 on: September 17, 2015, 12:27:44 PM »
When stripping an old engine block, I heat the plug and then hold a candle on it, melting wax around the threads. As it cools the wax is drawn into the threads. If it doesn't work the wax prevents penetrating oil from doing its job is a drawback from this method but enough heat will usually get rid of the wax. It does usually work though
« Reply #10 on: September 17, 2015, 12:30:48 PM »
Make certain to use only a six-point plug socket. A pox upon the mechani-saboteurs who came up with and foisted upon us the twelve pointers.
Be certain to have the insulator protector in the socket.
Try a 3/4 attempt at tightening once or twice.
Use nothing that flexes like a cheap breaker bar - aptly named tools, those!
Todd.
« Reply #11 on: September 17, 2015, 12:55:05 PM »
Wait, I want to be there when he sticks the head in the oven.
Offline redrider90
« Reply #12 on: September 17, 2015, 01:20:41 PM »
Todd.
A pox upon those Brembo F09  6 mm dual nipple bleeders!
Red 90 Mille GT
Offline NCAmother
« Reply #13 on: September 17, 2015, 01:46:42 PM »
If you have an air compressor with impact gun, correct spark plug socket, set the pressure fairly low, and shake it out
Howdy
Offline guzziownr
« Reply #14 on: September 17, 2015, 02:07:10 PM »
Thanks for all the suggestions:
(1)  How do you remove the head with a spark plug blocking the bottom nut?
(2)  I use an Eldorado fork tube as my breaker bar.  Not a lot of flex there.
(3)  No rattle gun in the garage.
Offline Mike Tashjian
« Reply #15 on: September 17, 2015, 03:12:33 PM »
If you are parting this bike out, I would remove the intake and exhaust. If a valve is open you can squirt whatever you decide in through there.  Then it would be a good time to invest in a impact tool. What are the chances you won't need it to take other items off this bike.  Mike
Offline guzziownr
« Reply #16 on: September 17, 2015, 04:02:58 PM »
Aha, good one Mike.  I will get right on that...
...Lotta gunk in those ports, time for the breaker bar.  Hold my beer...
SNAP!   SNAP!  Now I can get those heads off.
Former Champions:
DW
« Last Edit: September 17, 2015, 04:41:55 PM by guzziownr »
Offline Peter from Sch'dy
« Reply #17 on: September 17, 2015, 05:03:35 PM »
Now you can get at those pesky head nuts!
Best,
Peter
Online rodekyll
« Reply #18 on: September 17, 2015, 05:28:21 PM »
Autolite, Champion, AC -- all good for seizures in aluminum aircooled heads.  We pulled threads on VW heads all the time.  Bosch, Beru, NGK -- much better.
Sometimes these were so stuck that we assumed t-serts were in order and just hit them with a rattle gun.  If yours still doesn't want to come out, break the ceramic and center electrode off the stuck plug to access the head nut, pull the head and deal with it on the bench.
« Reply #19 on: September 17, 2015, 05:31:23 PM »
« Reply #20 on: September 17, 2015, 07:00:31 PM »
 :1: :1: :1: :1:
be careful with brake cleaner.. I avoid breathing it cold. Don't even think about heating it.
Offline tris
« Reply #21 on: September 18, 2015, 01:20:37 AM »
I want to be there when his Missus finds out he put a cylinder head covered in brake cleaner and olive oil in the oven
She'll probably spontaneously combust - let alone the flammable fluids on the head  :thewife: :thewife: :thewife:
1993 TW125 "POS" - Resting
