Author Topic: used tire  (Read 7000 times)
Offline Eric
used tire
« on: September 21, 2015, 02:25:10 PM »
I recently bought a tire changer and I didn't want to practice on one of my own rims so I bought a wheel and rim on Craigslist for $50 so I could practice on it. As it turns out, it's the size that would fit my Norge which now needs a new tire and the tread is in pretty good shape. But there is some rippling on the tire, perhaps from a track day. Do you think it can be used?
07 Norge
15 BMW F 800 R (Lori's bike)
2016 Ural Patrol
13 Triumph Bonnie w/sidecar
Moorhead, Minnesota
Gone: 2005 Ural, 2011 Ural, 2003 EV, 2005 750 Breva
Re: used tire
« Reply #1 on: September 21, 2015, 02:28:19 PM »
Looks like track day use to me.
Check the date code, and if the tire isn't more than a few years old, it "might" be OK.
Since you don't know how many heat cycles it saw at the track, you won't really know if the tire is any good until you try it.
Me?  I'd buy a new tire if it was going to be on a bike I was going to use for a longer rides, or out of town trips.
Offline Groover
    • Scooteropolis
Re: used tire
« Reply #2 on: September 21, 2015, 02:45:17 PM »
I'm interested in seeing the tire changer. I tried irons, and that was a disasters...
As far as the tire goes... I'd also buy a new one.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Re: used tire
« Reply #3 on: September 21, 2015, 03:00:30 PM »
 Yeah , new tire .
Re: used tire
« Reply #4 on: September 21, 2015, 03:07:12 PM »
I'd ride it
Re: used tire
« Reply #5 on: September 21, 2015, 03:13:28 PM »
I'll try carefully to answer the question that was asked, since sometimes I answer a question that I have the answer to, rather than answering what was asked.
"Do you think the tire can be used?"
Certainly I do.   It could be spooned back onto a rim, the bead seated, it would probably hold air, and would support the bike and rider.   But that's just my opinion.
The question that I have the correct and undeniable answer to is:
"Would Lannis put this tire on his bike, load it up, and ride it down the highway at 70 MPH?"
Absolutely not.   I'd buy a new tire and use it no matter how "tempting" it would be to save a few bucks.
Re: used tire
« Reply #6 on: September 21, 2015, 03:14:04 PM »
I'd ride it
Looks like a Pilot Power 2CT.  Nice sporty tire, but probably won't last long on the street.  Especially after a few track days...  And especially if it's six or seven years old...
Re: used tire
« Reply #7 on: September 21, 2015, 03:14:35 PM »
If you felt the need to ask you probably are looking for validation to use a used tire. Is the difference in price worth it? You have only two small patches of tire in the road, why save a few bucks there?
Tires are a safety item, like brakes. The typical consequences of a tire failure at speed are very different for a car vs a bike. Are the few $ really worth the risk?
Re: used tire
« Reply #8 on: September 21, 2015, 03:16:21 PM »
Yeah,  I'd watch the wear bars and take it to the twisties.
Online Perazzimx14
Re: used tire
« Reply #9 on: September 21, 2015, 04:53:07 PM »
If your interested in getting your own tire changer look no further than a No-Mar classic. All you need is the changer, tire lever, yellow thing, lube and two small tire irons. You do not need the spool adapters for spoke wheel or all the other widgets they sell. I have changed easily 125 tires on mine in the last 2-1/2 years without much drama. Cast, tubed, tubeless, spoke, an even the dreaded Goldwing tires. Best thing Is they also make beer. Every time I change a tire for a buddy a case of beer seems to fine its way to the fridge.
« Last Edit: September 21, 2015, 05:02:39 PM by Perazzimx14 »
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline Silver Goose
Re: used tire
« Reply #10 on: September 21, 2015, 04:56:04 PM »
You bought the tire/rim for practice,so, practice. The tire is scrap or the P.O. would have save it to be used for another track day.
Walk away form using on your bike. $50.00 tire of unknown use = scrap.
How much will it cost if the tire went down in the middle of a turn?
Good Luck
2007 Norge
2002 BMW K1200 LT
1959 Indian/enfield
1964 Norton
2008 Can Am Spyder
Offline Eric
Re: used tire
« Reply #11 on: September 21, 2015, 04:59:12 PM »
No, not at all. I'm of the same opinion as you regarding safety and I have the money for a tire. I honestly don't know what the ripples mean and how it affects the tire and safety. If the ripples means nothing and the tire is safe, it seems bad for the pocketbook and the environment to throw it out needlessly. If there is question about safety, I would never ride on it. I have reached an age where it is no longer mathematically possible to die young, so I don't intend to try.
07 Norge
2016 Ural Patrol
Moorhead, Minnesota
Offline Eric
Re: used tire
« Reply #12 on: September 21, 2015, 05:00:41 PM »
Good Luck
Yes, and I will. It's a bit more complicated than that when it comes to why it was sold, but your point is well made and taken.
07 Norge
2016 Ural Patrol
Moorhead, Minnesota
Offline Eric
Re: used tire
« Reply #13 on: September 21, 2015, 05:02:12 PM »
Yes, that's the one I got. Or it might be the next one up. I'm not sure. In any case, I got it mostly for Ural tires which no one seems to be able to mount without screwing them up. I screw them up to, but it's cheaper. That's why the practice wheel.
07 Norge
2016 Ural Patrol
Moorhead, Minnesota
Re: used tire
« Reply #14 on: September 21, 2015, 05:13:55 PM »
The ripples are a result of the tire getting really hot, and the rubber balling up under braking and acceleration.  It looks real typical for a track day tire.  The tire was probably ridden on the street a bit, after the track day, because the ripples are smoothed out a bit.
My guess it was part of an extra set of wheels/tires that someone used for thier trackday fun.  Like I mentioned earlier, find the date code on the sidewall, and if it dates back more than a few years, don't use it.  The Power 2CT has been around at least eight years, so it could be an old tire.
Here's some trackday pix of my Sport 1100's Bridgestone BT-014 tires.
Offline Eric
Re: used tire
« Reply #15 on: September 22, 2015, 10:05:57 AM »
Thanks for the input. Looks like it isn't worth the keeping. I just didn't want to add one more tire to the pile that our earth is trying to absorb if it wasn't necessary.
07 Norge
2016 Ural Patrol
Moorhead, Minnesota
Re: used tire
« Reply #16 on: September 22, 2015, 10:09:35 AM »
Like many things today, tires are recycled...
...if they are taken to a recycle center.
Offline Eric
Re: used tire
« Reply #17 on: September 22, 2015, 10:12:40 AM »
I will sleep better.  :smiley:
07 Norge
2016 Ural Patrol
Moorhead, Minnesota
Online Perazzimx14
Re: used tire
« Reply #18 on: September 22, 2015, 12:47:12 PM »
$2 per tire in Pennsylvania for a recycle fee. Take them to any tire shop pay $2 per and throw them on the pile. I just took in 26 tires I accumulated since April of this year :thumb:
Re: used tire
« Reply #19 on: September 22, 2015, 12:50:46 PM »
All that time in the burnout pit can be pretty expensive then .... ?
redrider
Re: used tire
« Reply #20 on: September 22, 2015, 04:25:12 PM »
" didn't want to add one more tire to the pile that our earth is trying to absorb if it wasn't necessary"
A few billion years and the Earth gets absorbed. I would run it and if it felt greasy, buy a new one. BTW, I have a brand new in the wrapper PR2 rear, 180 17 I do not need. PM me if interested.
