Author Topic: Ethanil not ethanol  (Read 3776 times)
Offline jbell
  • Some progress
Ethanil not ethanol
« on: September 22, 2015, 08:23:40 PM »
It appears only to be available in UK.  Anyone know if it's real or just a snakeoil fix to remove ethanol from fuel???  Sure sounds good but how do you dispose of the removed ethanol?   Any info out there?
'76 Guzzi T3   Future project
'78 Guzzi G5  Current project
'81 Guzzi G5  Organ donor
'92 BMW K75RT  On the road
Offline Steve Scott
  • Ride, Fettle, Repeat
Re: Ethanil not ethanol
« Reply #1 on: September 22, 2015, 09:18:45 PM »
It's not snake oil, it's just removing most of the ethanol by adding water and forcing phase separation and settling. The trick would be making up for the octane rating drop after the ethanol is settled out.
Also, the fuel would lose its ability to hold water in suspension until it's burned. Water would just settle in the lowest parts of the fuel system and cause rust or ice plugs... just like the old days.
'79 Morini 500S
'00 'Guzzi Jackal
'67 Teisco ET-440
Spring Grove, PA USA
Offline jbell
  • Some progress
« Reply #2 on: September 23, 2015, 05:10:11 PM »
Thanks Steve.  Guess I'll keep on stopping by the airport and getting AvGas with lots of octane, a bit of lead and no ethanol.
Online Perazzimx14
« Reply #3 on: September 23, 2015, 06:06:39 PM »
Low lead AV fuel in the States actually has lots of lead in it compared to traditional leaded gasoline. I am not sure how much ethanol is in your fuel but the 10% in the States hasn't negatively effected any of my bikes,,,.well other than fuel economy.
Lots of octane and high levels of lead is not the best combo for your Guzzi.
Offline sib
« Reply #4 on: September 23, 2015, 06:29:38 PM »
If you want to saturate your fuel with water, and at the same time lower its octane number, that's your business, but I much prefer to leave it, with its ethanol content, as it comes out of the pump.  It's true, however, that Ethanil is a cute name.
« Last Edit: September 23, 2015, 08:24:43 PM by sib »
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline jbell
  • Some progress
« Reply #5 on: September 26, 2015, 04:42:47 PM »
Mr Bell , what model of motorbike are you riding ? You probably don't need the octane , and lead isn't good for modern engines.
Dusty, I'm riding a '75 Ducati 860 GT.  The Guzzi ('78 G5) is a long way from running though I had planned to put AvGas in it, also.  Am I reading my replies correctly in that 10% ethanol pump gas is better than AvGas?  ..........Jack.
Offline Two Checks
« Reply #6 on: September 26, 2015, 06:30:05 PM »
Av gas isn't made for auto/bike engines which idle, vary the rpm, etc. Avgas is made for engines that normally stay at a set rpm and not a high rpm at that. It has a completely different additive package than mogas.
1987 1000 SPII "Il Duce' II"
Online Perazzimx14
« Reply #7 on: September 26, 2015, 08:39:36 PM »
For what my opinion is worth.......Yes.
« Reply #8 on: September 26, 2015, 09:09:52 PM »
Any opinions on the 104 Octane additive and pump ethanol gas?  I've been adding Lead substitute to my Eldo's gas. :shocked:
Offline jbell
  • Some progress
« Reply #9 on: September 28, 2015, 05:30:22 PM »
Thanks, Perraz and Two Checks, you've just made my life easier.
