Author Topic: Gearbox clutch adjust V7 II  (Read 1819 times)
Offline Jim C
« on: September 26, 2015, 11:52:03 PM »
When should I think about adjustment at the transmission?
I had to adjust the clutch lever again yesterday. Almost got
stuck at a light. This is the second or third time after taking
delivery. I can see some stretching, but not in less than 200
miles.
« Last Edit: September 27, 2015, 02:37:54 AM by Jim C »
2016 Red V7 II Stone
Offline sib
Re: Gearbox clutch adjust V7 II
« Reply #1 on: September 27, 2015, 06:36:09 AM »
miles.
Sounds like something may be loose.  Or, as happened to me on my '13 Stone, the cable itself might be defective.  On mine, it was a damaged end crimp at the handlebar end.  As the individual wires let go one by one, the cable would get slightly longer, until the end came off completely (fortunately, in my driveway as I returned from a longish ride).
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline SeanF
« Reply #2 on: September 27, 2015, 11:56:15 AM »
If memory serves, the clutch arm on the v7ii is easy to reach. When you press the cable end of the arm forward, how much travel is there before it contacts the outer body (using the big block terminology)? You just need *some* distance there.
On my '14 v7, I was able to find a happy spot by sticking my finger under the righthand side cover until I felt the clutch arm. Press it forward to overcome spring pressure until it touches the outer body. Minimize the gap there, just ensure there is a gap. Repeat when the bike is warmed up, and "bob's your uncle." I found it very easy to have too much free play when only using the feel at the lever to adjust freeplay.
