Author Topic: 03 EV Breather Box and Oil  (Read 1977 times)
Offline Wild Bill Guzzi
« on: September 27, 2015, 05:52:00 PM »
When I removed the air filter, I notice an oil puddle down in the breather box.  Any reason why this would happen?  The EV has 42,189 wonderful miles.
« Last Edit: September 27, 2015, 05:52:56 PM by Wild Bill Guzzi »
Online Wayne Orwig
Re: 03 EV Breather Box and Oil
« Reply #1 on: September 27, 2015, 06:46:31 PM »
Yes, You had the oil level a bit over filled. The crankcase blows out of the vent system into the frame. At the top of the frame under the tank, the excess oil in the frame then can vent into a hose to the air box.
There is an airbox drain hose behind the seat/helmet key lock. If there is a bit too much oil in the airbox, that will drip onto the ground.
A little of it is normal. If it is excessive, and it starts draining out of the airbox, you may want to verify that the oil level is not too high.
« Reply #2 on: September 27, 2015, 07:17:16 PM »
Mr. Orwig,
I will check the level.  Thanks
