Author Topic: EV1100 brake correction device  (Read 6179 times)
Offline jmac851
« on: October 03, 2015, 11:41:06 AM »
Can anyone explain what this "brake correction device" actually does?  I have this on my 1998 but not on my 1996.  Both are California models.
1967 V700
1969 Ambassador
1984 Cal 2
1996 Cal 1100
1998 EV 1100
2006 Breva 1100
1994 BMW R1100RS
Re: EV1100 brake correction device
« Reply #1 on: October 03, 2015, 12:01:36 PM »
 Are you referring to the proportioning valve for the linked brakes ?
Offline jmac851
« Reply #2 on: October 03, 2015, 12:40:41 PM »
I'm referring to the part that is located on the underside of the left leg of the swing arm. A brake line comes from the distribution block down to this thing and then another line goes out to the rear brake caliper.
1967 V700
1969 Ambassador
1984 Cal 2
1996 Cal 1100
1998 EV 1100
2006 Breva 1100
1994 BMW R1100RS
Offline pehayes
« Reply #3 on: October 03, 2015, 12:43:55 PM »
There is a spring connecting the swingarm to this 'balancing' valve.  When you add weight to the rear of the bike (luggage or passenger) the swingarm rises and changes angle.  The spring linkage interprets this change and then shifts or adds more hydraulic pressure to the rear brake disc.  Conversely, when riding solo, there is less pressure to the rear brake.  The idea is to prevent a rear wheel lock and skid.  With more weight in the rear, the bike can handle more braking pressure without lockup.
Its a subtle system.  I'm not sure just how accurate it is.  However, if you change from stock length shocks, you also have to modify the adjuster screw so that the same amount of swingarm deflection results in the same amount of pressure alteration.  See my explanation here:
http://www.guzzipower.com/IntegEVBrakes-Pat_H.html
I'm not a professional engineer.
BTW, that connector spring ($2) broke on Regina's 98EV during warranty.  They refused a free replacement as it was considered caused by abusive riding and improper braking technique.  ??????  Nice job Guzzi.
« Reply #4 on: October 03, 2015, 12:50:31 PM »
 What the esteemed Mr Hayes is saying is that YES , it is a front rear brake proportioning valve .
Offline sib
« Reply #5 on: October 03, 2015, 01:07:25 PM »
All things considered, it's a crude way to prevent wheel lock-up. I prefer the ABS on my '16 Stone.  I know that many enthusiasts here like the older bikes, but sometimes progress does occur.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
« Reply #6 on: October 03, 2015, 01:47:24 PM »
I've experienced that kind of crap from other companies before.  Their lawyers tell them that replacing it free is an admission of a defective part of a safety related system, so their official line is it's a customer caused problem.  It happened to me with a broken bicycle crank, and I saw it happen to a friend when an aluminum casting on his ultralight's pontoon mount broke, causing a crash landing into the water.  Abuse by the customer, metal fatigue due to old age, etc..  They can come up with lots of reasons their parts didn't cause the problem.
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #7 on: October 03, 2015, 05:56:58 PM »
Progress?  Then why was it dropped on the later Vintage models?  Since the foot brake also operates one of the front discs, it is too easy to lock the rear wheel when braking hard without this simple addition, especially if the rear wheel gets airborne.
Offline jmac851
« Reply #8 on: October 03, 2015, 08:11:33 PM »
My 96 1100i doesn't have one.
1967 V700
1969 Ambassador
1984 Cal 2
1996 Cal 1100
1998 EV 1100
2006 Breva 1100
1994 BMW R1100RS
« Reply #9 on: October 03, 2015, 08:19:32 PM »
It was explained to me as a kind of anti-dive device.  If you use too much front brake the nose wants to go down and the tail pitch up.  When that tail pitch happens it pulls the spring and auto-applies a little rear brake to counteract the dive.  Also called an 'anti-jack' valve because it damps the rear 'jacking' effect of a driveshaft bike.
But I have no idea what the factory might have had in mind.
« Reply #10 on: October 03, 2015, 08:26:40 PM »
The EV has linked brakes, rear + left front.
« Reply #11 on: October 03, 2015, 08:32:41 PM »
Yes, mine does.
Offline jmac851
« Reply #12 on: October 04, 2015, 07:19:45 AM »
My 1984 had linked brakes without this device. My 1996 has linked brakes without this device. After many miles on both, I never had a problem with the back brake locking up.  The proportioning valve is located on the outlet for the front brake from the distribution block.  It opens and lets fluid flow to the front brake after 5-6 bar of pressure is applied.
1967 V700
1969 Ambassador
1984 Cal 2
1996 Cal 1100
1998 EV 1100
2006 Breva 1100
1994 BMW R1100RS
« Reply #13 on: October 04, 2015, 12:28:51 PM »
Neither your 94 ot 96 had a lot of things that the EV did -- like the dogbone driveshaft, efi, wider swing arm, fatter tires, etc.
They did have a tendency to jack the swingarm though, and that's what the brake thingy is supposed to help with.
Offline PandionExpress
« Reply #14 on: June 05, 2018, 07:51:56 AM »
I know I am a few years late on this thread, but where did you find that spring for $2?  I am finding it for $20 at https://www.piaggiopartspro.com/oempartfinder.htm?aribrand=MGZ#/Moto_Guzzi/GU017_California_Special_1100_1999-2000/Front_LH//rear_brake_system/01%7C~GU017/GU017%7C~3316
Andrew
Andrew
1999 California Bassa - Pearl White
Offline pehayes
« Reply #15 on: June 05, 2018, 01:40:09 PM »
Andrew
That was nearly 20 years ago!  The broken spring was within a  year or two of purchase and should have been under warranty.  Probably the price back then.  I wouldn't have a record that far back.
« Reply #16 on: June 06, 2018, 07:38:58 AM »
Ahh, well that would certainly explain the order of magnitude change in price!  Thanks for clarifying that for me.
Noticed my spring was no longer connected to the braking correction device the other day. Figured it was worth checking if i could save almost $20 bucks.
Cheers,
Andrew
Andrew
