Author Topic: Moto guzzi 1100 breva left cylinder oil leak  (Read 5214 times)
MotoGuzziMiami
« on: October 12, 2015, 07:05:23 PM »
Hey friends!
So quick story I barely have the Guzzi for less than a year and last week I was riding on it and I felt a burning sensation on my left leg just as I was getting home from work.  Once I got home I noticed oil all over my left leg and sure enough the left cylinder was leaking oil... I cleaned up the cylinder and noticed the valve gasket leaking.  Now from doing my research I've noticed this is a common problem with the Guzzi?  Or did I do something wrong... also I read that this is reusable... forgive me for my lack of knowledge but how is it reusable if it is leaking... so I went out and bought a silicon gasket sealant I haven't put it on the valve gasket until I get the thumbs up if this is a good idea?
It is also due for an oil change so I'm wondering what oil and filter should I put on the bike with 5000 miles.
Looking forward to your response!!
Thanks again for letting me be a part of this forum!  Woot woot!
Re: Moto guzzi 1100 breva left cylinder oil leak
« Reply #1 on: October 12, 2015, 07:09:10 PM »
 The tappet cover gaskets are generally reusable , but nothing lasts forever . They are pretty cheap .
 Oh , and reading your intro , good start on a collection of bikes and welcome to WG .
Offline egschade
  • Eric - MGNOC NJ Rep - mgnocnj.forumotion.com
« Reply #2 on: October 12, 2015, 08:11:53 PM »
Order the filter along with the valve cover gaskets from a reputable Guzzi house like MPH out of Houston.
I use the 10w-60 specified in the updated B1100 maintenance. Been buying the Liqui Moly via Amazon http://www.amazon.com/gp/product/B00CPL918E?psc=1&redirect=true&ref_=oh_aui_search_detailpage
While you're replacing your valve cover gaskets may as well check the valve clearances...
The elder Eric in NJ
2024 Triumph 400X Scrambler
1971 Honda SL350
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
« Reply #3 on: October 13, 2015, 11:36:46 AM »
Absolutely not. It takes a very small bit of cured silicon to plug an oil way, and your engine is toast. Is it likely to happen? Maybe not, but don't take the chance.
Offline Dean Rose
    • Twin Valley Riders
« Reply #4 on: October 13, 2015, 11:52:15 AM »
http://www.realgaskets.com/files/motorcycle.htm
Just don't over tighten them, been on my two bikes for years NO leaks.
Dean
Magnolia '02 EV
Sophia '06 Breva 1100
Offline pehayes
« Reply #6 on: October 13, 2015, 01:46:28 PM »
Lets not jump to conclusions.  You sound new to Guzzi so some further analysis may be in order.
1-can you post a photo of where you think the leak is occurring?  If not a photo, perhaps a detailed physical description of the location.  Why do YOU think it is the valve cover gasket.
2-You've had the bike a year and only now it starts leaking.  Did you or someone else do any inspection or maintenance to the head recently?  It would be exceedingly rare to see a valve cover gasket just suddenly begin to leak profusely.
3-avoid the silicone seal.
4-There are other possible sources besides the valve cover gasket.  Oil pressure sensor?  Timing sensor?  Oil feed lines.  etc.  There is a lot of air flow over the engine and a leak at one location can quickly appear as a drip at another location.  Hate to see you make this simple gasket replacement repair and still find the same leak.
Offline Bisbonian
  • Living the Dream
« Reply #7 on: October 13, 2015, 05:23:46 PM »
The couple of times I've had a valve cover gasket let go on my 1200 Sport it has happened suddenly with zero extra input from me.
Offline flip
« Reply #8 on: October 13, 2015, 05:28:18 PM »
Dean
 :1:
I put those on my Breva 1100 last year after getting leaks around both valve covers within a few days. I haven't ridden it much in the past year or so since putting the new gaskets in but no leaks so far.
North Carolina
MotoGuzziMiami
« Reply #9 on: October 14, 2015, 08:26:36 AM »
I will send pictures soon!
« Last Edit: October 14, 2015, 08:28:21 AM by MotoGuzziMiami »
MotoGuzziMiami
« Reply #10 on: October 17, 2015, 05:51:43 PM »
Hey guys, so I'am installing the gasket now. Turns out the gasket was actually ripped apart. I'm placing the metal gasket as recommended. Thanks again for all your input. Posting pics soon
The "new" style metal-core gaskets are what I'd recommend.
http://www.mgcycle.com/index.php?main_page=product_info&cPath=170_174&products_id=4634
Filter:
http://www.mgcycle.com/index.php?main_page=product_info&cPath=164_167&products_id=2570
One choice for oil:
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Motor-Oil-Liqui-Moly-RaceTech-100-Synthetic-10W60-5l/_/R-AORLM2024_0435903878
MotoGuzziMiami
« Reply #11 on: December 11, 2015, 07:34:13 AM »
Working like a champ!
Haven't had the time to say thanks for the advice. :thumb: :thumb: :thumb: :thumb: :thumb:
