Author Topic: tonti clutch question  (Read 2212 times)
Online lazlokovacs
« on: October 15, 2015, 08:47:46 PM »
clutch question..
does there need to be a gap between outer body of the clutch rod (eg. GU14086100) and the adjuster screw on the clutch arm or can they be in constant contact?
on my bike the outer body is protuding due, i imagine, to worn clutch plates, and the arm is hitting the frame..
thanks as ever
Offline acogoff
Re: tonti clutch question
« Reply #1 on: October 15, 2015, 09:01:57 PM »
    Possibly you have a throwout bearing coming apart. Easy enough to take apart for a look.
« Last Edit: October 15, 2015, 09:02:28 PM by acogoff »
Marshall County Minnesota USA
Offline jacksonracingcomau
« Reply #2 on: October 15, 2015, 09:23:41 PM »
clutch question..
thanks as ever
Clutch arm needs free play, yours will slip wildly like this
adjust screw out till you have some, if impossible, plates are toast (from having none)
Online lazlokovacs
« Reply #3 on: October 16, 2015, 06:24:15 AM »
cheers martin.
(bugger. just when everything else was coming together..)
