Author Topic: Intake vacuum adapters  (Read 2921 times)
Offline Karl Von
    • Classic Old Motorcycle Association
« on: October 21, 2015, 09:40:08 PM »
Does anyone know a source for 6mm vacuum nipples that go into the intakes ?
Offline Scud
Re: Intake vacuum adapters
« Reply #1 on: October 21, 2015, 09:54:41 PM »
You looking for the metal parts or the rubber caps? Caps and clamps are easy at auto parts stores. I would imagine you could get the metal parts at most auto stores too.
1989 Moto Guzzi LeMans
2017 Husqvarna 701 Enduro
2017 Moto Guzzi Stelvio NTX
2020 Yamaha TW200
Offline Farmer Dan
« Reply #2 on: October 21, 2015, 09:55:16 PM »
I made mine with some copper tubing and a die.  Just takes patients.
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
« Reply #3 on: October 21, 2015, 10:14:08 PM »
Motion Pro sells them, most bike shops will have them in stock.
Offline nc43bsa
« Reply #4 on: October 22, 2015, 12:37:16 AM »
I made mine out of a pair of screws and nuts.
1990 MilleGT
« Reply #5 on: October 22, 2015, 12:42:56 AM »
This is the easy way.
« Reply #6 on: October 22, 2015, 06:10:46 AM »
A grease zirk will work. Just take a smidgen off the threaded end. The spring and check ball will come out, and you have a vacuum port, complete with threads. Free from your "good junk" box.  :smiley:
« Reply #7 on: October 22, 2015, 08:42:15 AM »
Tips for a mig welder fit right on and last forever in this application . Small Millers, probly up to 180, there are different tips but the small ones are metric threaded. I used the ones for the largest wire , otherwise I drill them out, either way works
