Author Topic: Flat tappet issue  (Read 5803 times)
Offline Jdcooper
Flat tappet issue
« on: October 22, 2015, 10:07:24 AM »
I'm a Guzzi newb here. Owned my 09 Stelvio for less than a week...and love it.
As w most new owners I'm trying to learn everything I can as quickly as I can, and the flat tappet
problem is high on the food-chain of issues I'm studying.
Moto Guzzi's are far from the only brands which suffer cam/tappet damage. Many vintage cars
have the same issue. Within the motorcycle world the KLR250 and Suzuki Savage do too. Most owners
accommodate for this problem by adding ZDDP into their oil. This compound has been deleted from "modern" oils
because it coats the catalytic converters of "modern" engines.
Has anyone looked into oil additives to prevent damage ?  SOMEONE has to have "been there..done that" .
Here is a short quote from a pertinent article:
Motor oils designed for vintage engines have more ZDDP than API-SN. The ZDP family decreases wear on highly loaded rubbing surfaces. In the vintage engine this is most prominently the camshaft-lifter interface. The problem with ZZDP in API-SN oil is that the phosphorus in the zinc dithiophosphate coats the active substrate in catalytic converters.
The full piece is here:  http://www.classiccarmotoroil.com/articles.html
I am NOT trying to start another oil war....just wonder if anybody has researched the problem.
Thanx !         Coop
Re: Flat tappet issue
« Reply #1 on: October 22, 2015, 11:21:48 AM »
Thanx !         Coop
Hi, Coop.. welcome to WG. Yeah, a search on here (upper right) will probably give you a fair amount of information on ZDDP.. flat tappets, and roller conversions.  :smiley:
 :popcorn:
« Reply #2 on: October 22, 2015, 11:35:46 AM »
While some additives can provide some benefits, rarely can they prevent or fix design or manufacturing problems.
The fix is rollers. Well, that and some money on your end.
Given the cost of most additives, they might cost more in the long run than additives that might only postpone the problem anyway.
Offline pyoungbl
« Reply #3 on: October 22, 2015, 01:39:22 PM »
OP has an 09 Stelvio.  That's a 4V lump.  The flat tappet/roller tappet issue only applies to the 8V.  There is no roller conversion for the 4V engines.  The sky is not falling!  Worry about running out of gas or some other problem that applies to the 09, not the tappets.
Peter Y.
'13 V7 Special (red/white)
Offline Bisbonian
  • Living the Dream
« Reply #4 on: October 22, 2015, 02:03:32 PM »
Peter Y.
I thought all Stelvios had the 8V engine?
« Reply #5 on: October 22, 2015, 02:06:22 PM »
Biz - think you're correct re all Stelvios came with 8v engines. I believe the Stelvio was the only CARC bike not to have been initially powered by a 4v engine.  There were 4v Breva and Griso 1100s, 1200 Sports and Norges.  So I think the OP's 2009 may be "Version 1.01," 8 valves with flat tappets prior to the DLC-coated flat tappets.
« Last Edit: October 22, 2015, 06:25:47 PM by ohiorider »
Offline Aaron D.
« Reply #6 on: October 22, 2015, 02:18:43 PM »
Pretty sure an 09 is a 4v
« Reply #7 on: October 22, 2015, 02:29:55 PM »
Peter Y.
Peter, all Stelvios use the 8V engine. The 4V/8V thing is just a naming oddity.
« Reply #8 on: October 22, 2015, 05:04:37 PM »
What have you been smoking?
:boozing:
My 8V 2009 is waiting on kit C.
Of course, maybe I'm goofy and that is why I am still waiting. :laugh:
Offline Demar
« Reply #9 on: October 22, 2015, 05:07:02 PM »
:boozing:
You will get the kit when pigs fly.
2012 MG Stelvio NTX
2010 Bonneville T100
1953 Galletto 175
« Reply #10 on: October 22, 2015, 05:11:54 PM »
Awesome..
« Reply #11 on: October 22, 2015, 06:15:39 PM »
That's an empty threat where Wayne's concerned.   :laugh:
