Author Topic: V11 Sport/Le Mans Speedometer Cable Routing  (Read 1764 times)
Offline Redballabio1
« on: October 22, 2015, 02:48:12 PM »
Hey guys,new member here looking for help with the routing of the speedometer cable on my '04 Ballabio.I have a memory of changing the routing of the speedo cable as it leaves the transmission and passes under the throttle body several years ago.There is a brace and the linkage to the other throttle body in that area.I've had issues with the cable fouling the  linkage and causing a high idle.I use the correct cable for the Ballabio/Cafe Sport #01760481 and since i'm installing a new one now I'd like to get it right.If someone could post a picture of the cable as it passes under the throttle body or offer some direction,I'd really appreciate it.
Thanks in advance,
Mike
