Author Topic: sidestand disconnect - yes, I know it's been explained before but...  (Read 3988 times)
Offline Eric
... I still can't find out how to do it. Temporary only to troubleshoot so no need to tell me it's a bad idea. I already know.  Here's what I see under the 750 breva. Is this a molded piece or a plug I can force out? If it's the latter, is this were I try and jump the two wires? There seems to be no obvious wires to cut and connect.
But if I follow the line up (I think) I come to this connector. Can I jump it here and, if so, how do I do it?
07 Norge
15 BMW F 800 R (Lori's bike)
2016 Ural Patrol
13 Triumph Bonnie w/sidecar
Moorhead, Minnesota
Gone: 2005 Ural, 2011 Ural, 2003 EV, 2005 750 Breva
Offline Scud
Re: sidestand disconnect - yes, I know it's been explained before but...
« Reply #1 on: October 25, 2015, 02:12:28 PM »
Do you have a multi-meter? I'm going to assume you do.
I'm only familiar with the V11 Sports, but I think the switches must be similar.
On mine, the sidestand switch comes with a long wire and plug like the one you found. You should be able to separate that and plug a jumper cable across the two pins on the side that remains attached to the loom.
You can test resistance of the sidestand switch after you unplug it. Then you'll know for sure if you have the right connector - if you see a change in resistance when you deploy/retract the sidestand. If I remember right, you should have no resistance with the sidestand up (current can flow).
1989 Moto Guzzi LeMans
2017 Husqvarna 701 Enduro
2017 Moto Guzzi Stelvio NTX
2020 Yamaha TW200
elvisboy77
« Reply #2 on: October 25, 2015, 02:44:29 PM »
Unplug it.  Bike doesn't start?  Then jump it.
My CalVin just needed unplugged I believe.
Offline Eric
« Reply #3 on: October 25, 2015, 03:54:17 PM »
Are you referring to plug in the top picture?
07 Norge
2016 Ural Patrol
Moorhead, Minnesota
Offline Scud
« Reply #4 on: October 25, 2015, 05:07:49 PM »
Here's the switch, wire and plug from an 02 V11.  I assume (but do not know) that it's similar on other models.  On the V11, this plug is under the tank, not by the battery as in your picture. Again - the Breva could be different.
2020 Yamaha TW200
Offline Eric
« Reply #5 on: October 25, 2015, 06:12:02 PM »
Thanks. Got it.
07 Norge
2016 Ural Patrol
Moorhead, Minnesota
Offline sign216
« Reply #6 on: October 25, 2015, 07:01:54 PM »
I wrote a short essay about disconnecting the side stand switch for 750cc Guzzis:  https://www.flickr.com/photos/sign216/albums/72157625678641324
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
