Author Topic: griso runs on one cylnder FIXED WITH ROADSIDE ADVICE ON SPARE PLUG  (Read 3583 times)
Offline Gootsz
All
UPDATE
FOUND IT WAS A PLUG. BUT TRY AND FIND A NGK PMR8B ON THE ROAD. AUTOLITE 4303 CROSSES AND WORKS FINE. NOW IT IS JUST A REGULAR PLUG AND I WILL CHANGE WHEN MY NGK'S COME IN BUT BACK ON THE ROAD AND WILL KEEP IN THE BIKE. ONLY $2.50
I know the things i need to check have new plugs on order and some backup coils. New wire from coil to plug installed.
Anything else i should look at have basic diagnostics tools. Centurion VDST.
Micky
« Last Edit: October 29, 2015, 03:40:50 PM by Gootsz »
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
THERE ARE NO WINNERS IN ROOM FULL OF LOSERS
Re: 2009 griso runs on one cylnder under 2500rpm
« Reply #1 on: October 29, 2015, 02:43:09 PM »
Throttles badly out of balance perhaps
Offline acguzzi
« Reply #2 on: October 29, 2015, 02:59:16 PM »
blocked idle jet or channel?
Offline Gootsz
BUMP
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
Offline Gootsz
Re: griso runs on one cylnder FIXED WITH ROADSIDE ADVICE ON SPARE PLUG
« Reply #4 on: October 29, 2015, 03:41:09 PM »
BUMP2
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
« Reply #5 on: October 29, 2015, 03:50:50 PM »
Damaged plug cap. Can you see or hear the spark arcing to earth?
« Reply #6 on: October 29, 2015, 04:54:31 PM »
if a new plug fixed I would wonder if you had a bad connection with spark plug cap.   You might check if it's broken or cracked.
Offline Gootsz
« Reply #7 on: October 29, 2015, 05:10:51 PM »
Wire brand new. Never yanked just pryed out as instructed Pete.
By the way you are correct new map is VERY linear and smooth. hauls ass.
Thanks Mark and Pete.
Micky
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
Offline Gootsz
« Reply #8 on: October 29, 2015, 05:12:33 PM »
replaced with NGK cap/wire for sport. Old plug repeated failure.
micky
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
Offline NCAmother
« Reply #9 on: October 29, 2015, 09:43:02 PM »
micky
bummer, can you describe the ceramic and electrode?
Howdy
Offline Gootsz
« Reply #10 on: October 30, 2015, 08:35:49 AM »
All
i just did the last as an experiment to prove it was plug.
Tip darker than good one but did not look that bad. stuck in boot and hsa weaker spark. but i am not going to subject my new wire any more about than nessecary. i will hope i fixed it and go from there.
Thanks for all the support. :bow:
micky
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
