this should help
Brembo 13mm hand master cylinder repair kit for all late model V11 California 1100cc models with rectangular master cylinder reservoir and *** hollow lever pivot pin.*** If the pivot pin or bolt is hollow in the center, this kit will fit. This kit does not fit early rectangular master cylinders with solid lever pivot pin. Also fits some 13mm rear master cylinders, compare photo with yours to be sure.
Brembo front 13mm master cylinder repair kit, V11 California
[Part Number: 110436250]
