Author Topic: My oil pan 75 850 T  (Read 1629 times)
Offline Woodrow
My oil pan 75 850 T
« on: November 04, 2015, 10:29:45 AM »
   Greetings from Northern Wisconsin
  Yesterday I went to take the oil pan off the 850 , I removed 14 screws and 4 more from the bottom .   Did I miss something .?
How tight can this gasket be ?
   Do I need a bigger hammer ?    Hope not .
   Too bad I was ready to give it a good fresh oil ride , it was 70 deg here ,  Gadzooks !
Woodrow
Offline Aaron D.
Re: My oil pan 75 850 T
« Reply #1 on: November 04, 2015, 10:47:15 AM »
No filter, so put the bolts and plug back in and ride.
Offline TOMB
« Reply #2 on: November 04, 2015, 10:59:39 AM »
Look at the front of the oil pan if you see 3 plugs slightly  smaller than a dime your
Engine has a filter no plugs no filter. But the pan that old may have been  modified
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
« Reply #3 on: November 04, 2015, 11:06:04 AM »
some doofus probably use gasket goo and now it's glued on.  warm it up good and tap on the front w/a rubber mallet.
« Reply #4 on: November 04, 2015, 11:49:55 AM »
Notice the OP said 14 around the perimeter and 4 more on the bottom. Only filter engines have that configuration.
Use a long pry bar with the tip against the bellhousing and the shaft against the drain plug (threaded all the way in and tight). That should break it loose even if someone has glued the pan on.
Offline Woodrow
« Reply #5 on: November 04, 2015, 12:00:20 PM »
Thanks Charley.     Will try the bar method .   And  true,   it is a late 75 with deep sump.   I dont recall using any sealer on gasket last filter change .
  Woodrow
