Author Topic: Guzzi's answer to the new Triumph Classics?  (Read 4691 times)
Fangit
« on: November 05, 2015, 04:42:35 AM »
Offline Dogwalker
Re: Guzzi's answer to the new Triumph Classics?
« Reply #1 on: November 05, 2015, 04:58:00 AM »
No, only a graphic elaboration of Oberdan Bezzi, using an engine that will not be updated to meet the future pollution standards.
However, using the Bellagio base, there is better to me.
« Reply #2 on: November 05, 2015, 06:11:58 AM »
I LOVE those!    As you stated, the 2V(/cyl) big block will never get updated, but, they could put the current 8V motor should be a bolt-in.
Do it, Guzzi, DO IT GUZZI!
They should make a version of the Record fairing to fit it too!
Offline Murray
« Reply #3 on: November 05, 2015, 07:44:56 AM »
Alternator in the current 8valve will not fit into that frame.
Offline Dogwalker
« Reply #4 on: November 05, 2015, 10:15:51 AM »
Radical Guzzi managed to fit it into the Tonti frame. Is not bolt-in, but it's possible (they had their fair share of problems to solve, but mainly for adapting the transmission, that's not required with a Bellagio frame).
http://www.bikeexif.com/moto-guzzi-v7-custom
They used the old alternator obviously, but in a classic-naked there is no need of much electricity.
« Last Edit: November 05, 2015, 10:50:07 AM by Dogwalker »
Offline Tobit
« Reply #5 on: November 05, 2015, 10:31:34 AM »
V12 Stone.  I love that one.
Tobit
Roman, '86 LM IV
Online bad Chad
« Reply #6 on: November 05, 2015, 04:26:20 PM »
Not a chance!  Look at how huge that motor looks in that chase.   And how the hell would a small block frame handle the force put on it by a 100 plus horse power at the wheel?   Major changes would need to be made.  Much easier I would think to go with a big block frame.
Offline Murray
« Reply #7 on: November 05, 2015, 04:36:54 PM »
The Bellagio is a "big block" frame.
Offline JeffOlson
« Reply #8 on: November 05, 2015, 04:42:53 PM »
Someone mentioned in another thread that they liked the way you can see air/space around the engine on the Triumph Modern Classics. I hadn't really thought about that before, but I like that, too. Look at all the space around that engine!
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
Online bad Chad
« Reply #9 on: November 05, 2015, 04:56:43 PM »
OK my mistake.  It looked like a small box Tonti to me.
Offline boatdetective
« Reply #10 on: November 05, 2015, 05:00:11 PM »
I actually did pick up on that. It's a glaring issue with the current Bonnie. The "negative space" is a definite characteristic of the original. I am positive that this caused the engineers fits! I can imagine there were plenty of fights with the designers: "sounds cute, but where are we supposed to jam all the other crap??"
Once again, another reason to heap praise on the folks running the show at Triumph. This is a well thought out visual design from the ground up. I can't wait to see what designer Glynn Kerr from MCN has to say.
Jonathan K
Marblehead, MA
1981 V50III "Gina"
2007 1200 Sport "Ginger"
