Author Topic: Handlebar Switches  (Read 1283 times)
Loser-At-Life
Handlebar Switches
« on: November 08, 2015, 04:52:16 PM »
Been a while since logging in here !!!
The Lario hasn't given me any problems for a few years !!!!
I had the headlight and the tail light, parking light, indicator lighting switches go bad on my '87 Lario in July, didn't have time to work on the bike, until I got on vacation a few weeks ago, so I parked the Lario .
I didn't like the aftermarket combination switches, so I made up my own wiring and put three switches in a plastic project box on the right side of the fairing .
All the lights work as they should now .
So my question, I can now have both high nd low beam on at the same time, separate switches for each .
Will using both overheat the headlight assembly and damage it ????
I have a wiring harness that uses the bikes headlight circuits to operate relays and get battery direct power to the head light .
I was considering doing this for daytime use only .
Thanks for any suggestions !!
Re: Handlebar Switches
« Reply #1 on: November 08, 2015, 05:44:16 PM »
If the housing is glass & metal I would think it would hold up. I would make sure the plug on light is ceramic.  A sealed beam should also hold up.
