What you did worked , probably the best action Of course there is always ... When in doubt GAS IT Dusty
Was the 15 mph slower that could be taken by you 15 slower than the speed limit? If a road is posted for 45 but you can take it at 60, going 45 in bad conditions is an error in judgement. Bad conditions would be a lower than posted most likely.
Yeah that is a pucker. Had it happen here mostly on Farm to Market roads coated with farmer's dust/mud goo. Not fun, especially in curves that can be taken very fast as sweepers, but only if clean and dry. Definitely stay loose, chilly, don't brake and slight acceleration is your friend...it is ok to slide a bit.
Usually just focusing on the exit of the turn, and not reacting too violently will get you through. By the time you make a conscious decision you will be either through or down.Most slippery conditions, like a patch of gravel, end up being just a twitch anyway. Nailing the throttle could have you in the unhappy situation of the bike being near perpendicular to the direction of travel and may have you highsiding. Just focus on the exit, your subconscious probably knows what to do.
Dirt rider perspective:Get your weight on the pegs and maintain throttle - or gas it (a little). That "Gas it" advice is fine if you're running a huge knobby tire in rough terrain - but if you're already worried about grip, too much gas is not going to help (unless you are already used to the feeling of having the rear end swing around due to wheel spin). Weight on the pegs will let the bike shift under you; it lowers the pivot point of the bike relative to your body. When you are on the seat, a sudden shift of the bike goes up through your ass, and right to your head. When you have your weight on the pegs, the apparent shift of the bike is smaller - that's part of the reason that dirt riders stand up for the technical sections. Find a corner or curve you know with an annoying bump in it - then ride it a few times with more and more weight on the pegs - see how you feel about the bump then. The difference will be similar with debris (mud, sand, etc.).Just so I don't sound all "smarty-pants" I once low-sided a Ducati in a situation similar to what you described. Good on you for keeping it upright.
Helmet, leather gloves, chaps, boots, and a skid jacket. Walk away.
Way back in time, on a road far far away, at night, I was astride a 650 twin Yamaha back when it was only a year old, I was entering a curve at about 65. I had done this curve at that speed many times before and was not worried. It suddenly felt as if I were on an oil slick and was going sideways then like in slow motion I low sided and I lifted my inside leg so as not to have it under the bike and rode the bike to a stop in a huge shower of sparks as steel parts ground away against the pavement. I got the bike up and nursed it to a friends house a mile away and spent the night. My horsehide jacket had shredded both sleeves, My steel toed boots had ground down through the leather and looked like a disc grinder had been applied to the steel of the toes. My gloves had no palms , and The face shield and helmet appeared to have been held to a belt sander. The bike had been equipped with crash bars and plastic saddle bags and so took no functional damage. I carefully went to the crash in daylight and paced the distance from the first scar on the road to where the bike had stopped. 165 feet. The road was covered with a fine dusting of pumice that was as slick as graphite. St. Helens had erupted the day before and during the night the gray dust had settled on the road. It was the same color as the road and at night was quite invisible. As for my lowside, Under those conditions, I don't think any action on my part would have made any difference as to whether or not I crashed. It could only determine how I would crash.
This week, it wasn't an invisible powdery substance for me.. it was very visible corn, and no way to miss it and stay on the road. Decision time. Do I low side on the corn, or take the ditch? Pretty easy decision..
So what was the outcome ?
No, these are tight curves, I was going about 20 mph in a 35. In western NC, the curves aren't marked. Rider beware.
Had all the gear. Had a heavy leather riding jacket with armor in the shoulder and elbows. Not sure how well I'll skid though. Skidding versus tumbling probably makes a whole lot of difference in injury. Tough thing to practice.
what kind of tires and model of them do you have? how old and what mileage on them?What tire pressures do you run?all these factors can also lead to more slippage in turns.I personally change tires WAY before hitting the wear bars. I like good traction especially riding in the mountains.
Well then, since you are still among us, you don't need the wisdom, you've earned some privilege to pass some out wouldn't you say?
