Author Topic: Cali1400 Hanging throttle  (Read 5605 times)
Offline DaddyRabbit
« on: November 23, 2015, 09:31:24 AM »
in the last 2-3 weeks I've noticed that my throttle, upon release and the clutch pulled, hangs open at around 1800-2000 rpms.  Only occasionally, and predominantly when in traffic where the motor is hotter than at speed.  I searched here and found an old thread from 9/13, but no follow up as to the solution.  Anyone experiencing the same?  Anyone have a solution?  '14 Cali 1400 Touring, 9600 miles.
Ride with your kids...its cheap therapy for both of you.
03 Cali SS - gone
07 Vintage - gone
09 Stelvio -gone
13 California 1400
18 KTM 1290 SAS
Re: Cali1400 Hanging throttle
« Reply #1 on: November 23, 2015, 10:25:01 AM »
Make sure the tank breathers aren't pinched. Check your airbox isn't full of oil. Perform the 'Self Learning' functions for the demand sensor.
Offline Carmine
« Reply #2 on: November 23, 2015, 10:40:19 AM »
   Yes, I had the same happen to me under the same circumstances... Stopped, shut down, restarted, problem gone. Only happened once, after being in heavy traffic, it was also a hot day.
« Reply #3 on: November 23, 2015, 10:48:49 AM »
  Does the 1400 use fly by wire technology?
Lcarlson
« Reply #4 on: November 23, 2015, 11:02:31 AM »
Yes, it does.
Offline DaddyRabbit
« Reply #5 on: November 23, 2015, 12:44:39 PM »
thanks Pete. i'll check the airbox today and the rest i'll pass along to the mechanic tomorrow.  Other than this issue, she's been rock steady and a great pleasure to ride.
03 Cali SS - gone
07 Vintage - gone
09 Stelvio -gone
13 California 1400
18 KTM 1290 SAS
Offline ibis1
« Reply #6 on: November 23, 2015, 02:13:09 PM »
Mine is also doing that at times. Doubt if it's the throttle plate hanging up, but may be a defective throttle (Grip) potentiometer. Post if you find the solution.  :boozing:
2010 California Vintage (Gone)
1971 750 Ambassador (Gone)
2014 California Touring
Offline Aaron D.
« Reply #7 on: November 23, 2015, 03:46:41 PM »
I've seen this with other, non-Guzzi ride-by-wire throttles, so it isn't unique to your 1400.
Lcarlson
« Reply #8 on: November 23, 2015, 03:56:08 PM »
Mine seems to do this occasionally. It has no adverse effect, so I expect it's normal with the RBW.
Offline jones525
« Reply #9 on: November 23, 2015, 04:08:48 PM »
Unless the cables are binding mechanically, it'll be the "demand sensor" basically the TPS for a RBW bike. Could need a reset / calibration... Search for other posts by me here for details, what you describe happened to me but in a far more spectacular fashion...
Offline ibis1
« Reply #10 on: November 23, 2015, 06:00:26 PM »
Which cables are you referring to?  :boozing:
Offline DaddyRabbit
« Reply #11 on: November 23, 2015, 07:20:07 PM »
I searched for your previous thread regarding this, but didnt find anything.  I did, however, read your post in the brake problem thread and I have that going on as well.  Ill look in to that as well.
03 Cali SS - gone
07 Vintage - gone
09 Stelvio -gone
13 California 1400
18 KTM 1290 SAS
« Reply #12 on: November 23, 2015, 11:22:43 PM »
Might sound simple but do you have any bar end weights on. Loosen and remove the one on the throttle side. You might need an additional slim spacer of less a diameter than the bar to eliminate friction.
Yarvis
« Reply #13 on: November 27, 2015, 03:43:44 PM »
This has happened to me twice this year but only recently. I have been in horrible stop and go traffic this summer and it didn't do this. In the last 1-2 months it's happened at least twice after following this situation here and on other sites. Does anyone know what's involved in a reset and how to do it? Has anyone else found an exact fix for this? Why would this start all of a sudden so to speak?
Yarvis
« Reply #14 on: December 08, 2015, 05:30:26 PM »
ttt
« Reply #15 on: December 08, 2015, 05:42:38 PM »
If you want to reset the trims? Just disconnect the battery for a minute or two. If you want to do the self learning process for the demand sensor you'll need Guzzidiag or one of the proprietory tools like PADS.
Yarvis
« Reply #16 on: December 08, 2015, 05:46:50 PM »
Thank you! I'll disconnect the battery tomorrow to see what this does as my first process.
