Uhhh....OK. NOTHING written on this forum will ever change my riding habits.
If you have enough time to worry about your clutch cable snapping at a stop light, you have spent too much time worrying and not enough time enjoying riding.The short time you might spend at a stop light or stop sign isn't going to make one bit of difference, it the cable snaps or the clutch fails, it was going to do it anyway.If your cable snaps and you launch into the intersection, obviously you are in lala land and not paying attention.The clutch was created and designed to be used. Dragging or slipping the clutch excessively is harmful to them, like anything, the operative function here is excessive.A lot more people get hit from behind at stops than people have clutch cables snap at stop signs or lights.Anyone worried about a clutch cable snapping or the clutch wearing out hasn't ridden where steep hills exist. Most likely, they've never ridden two up and loaded or been in heavy traffic.You can buy auto tranny motorcycles, for the clutch operation challenged.If you want to worry about something, that clunck you hear when putting the trans in gear because you wanted to save your clutch or its cable was the sound of metal hitting metal. Clutches, like brakes, are wearable items, one day you might have to repair or replace it. Before that time, you will have spent many times that amount changing oil and filters unless you ride very infrequently so as not to get the oil and filter dirty.Its a clutch not a chastity belt.
Isn't tryptophan is sedative ? Let's play nice boys , it is thanksgiving . Dusty
Boy sometimes you spout a mixture of vitriol and nonsense that makes me wonder if you're cranky or crazy.But maybe we ask get a little cranky or crazy sometimes.
I've been riding for almost 50 years and have never been in a situation at a light where I had to "get out of the way quick." Maybe I've just been lucky. I was seriously schooled by my father, however, about breaking clutch cables. You don't want to be stopped, in gear, if that happens (and it did to him on an old Goldstar). I've had the clutch cable on my new V7 stretch while I was in heavy traffic on a hot day - that's no fun either. I sit in neutral at lights and try to use the clutch as little as possible. But that's just me.
Just trying to fit in with the rest if the crazies and crankies.
Sorry to burst your bubble, but....YES problem for a wet clutch or any clutch.You shouldnt sit at a standstill with ANY clutch wet or dry for extended periods of time. All you are doing is glazing up the clutch friction plates,heating up the steel plates and loading up the throwout bearing and gearbox input shaft bearing and on a wet clutch heating up and putting friction material into the oil.Any time you have the clutch disengaged for anything other than selecting gears or smoothing out the drive while riding slowly in traffic is a negative. Obviously the latter isnt exactly great but its less harmfull than bunny hopping along.Any clutch is at its happiest when fully engaged.Ciao
Here's another vote for putting the bike in neutral at a stop. I do the same with cars.Yes, if it is a short stop I will leave it in gear.Yes, I have used a clutch on many, many hills. That's where the foot brake is great and why I like handbrakes on a car that has a manual tranny.
FWIW, on a multiplate clutch there is always the possibility of contact between the surfaces when the clutch is disengaged. There is nothing in the mechanism that forces the intermediate disc and friction discs to separate.
