Author Topic: No high beam  (Read 3855 times)
Offline toolittletime
    • mysportgear.com
No high beam
« on: November 28, 2015, 07:42:49 PM »
Could a dirty contact in the ignition switch cause my high beam to stop working?
Blue indicator light (high beam) on dash not coming on either.
Thanks..
Tim
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
Re: No high beam
« Reply #1 on: November 28, 2015, 07:44:54 PM »
 Replace the headlight.
    • mysportgear.com
Re: No high beam
« Reply #2 on: November 28, 2015, 07:48:11 PM »
Will that make the indicator light come on?
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
Online Kiwi_Roy
Re: No high beam
« Reply #3 on: November 28, 2015, 07:54:55 PM »
This is an 07 Norge
http://www.thisoldtractor.com/guzzi007/schematics/2007_Norge.gif
It looks as though the high beam indicator is independent of the lamp itself,
See if you can locate the white wire and measure the Voltage to chassis
Some of the Norges have 2 headlight relays.
It may be the dimmer switch or wiring.
Looking at the schematic again it seems as though there are 2 different fuses associated with the headlights, the Low beam circiut goes through the relay R4
Check all your fuses
« Last Edit: November 28, 2015, 08:23:33 PM by Kiwi_Roy »
Offline Guzzidad
Re: No high beam
« Reply #4 on: November 28, 2015, 07:58:33 PM »
   Check if high beam comes on with the flasher button. If it does, then it's probably the high beam dip switch. If it doesn't it's probably a relay.
Re: No high beam
« Reply #5 on: November 28, 2015, 08:27:37 PM »
Switch
Re: No high beam
« Reply #6 on: November 28, 2015, 08:40:05 PM »
    • mysportgear.com
Re: No high beam
« Reply #7 on: November 28, 2015, 09:51:46 PM »
This is an 07 Norge
Sorry, should have specified this problem is on my 02 EV. I'll check tomorrow on some of the suggestions. Is there a good tutorial on cleaning the contacts in the ignition switch.
Thanks!!
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
Re: No high beam
« Reply #8 on: November 28, 2015, 09:58:58 PM »
Thanks!!
Handlebar switch.
Not likely do have anything to do with the ignition switch.
Might be the connector or a bad wire going to the handlebar.
« Last Edit: November 28, 2015, 10:00:22 PM by Wayne Orwig »
Offline SmithSwede
  • I don't want a pickle
Re: No high beam
« Reply #9 on: November 28, 2015, 10:30:33 PM »
A little Tareyton humor from Dusty.   Well played, sir
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Re: No high beam
« Reply #10 on: November 28, 2015, 10:51:42 PM »
 Seems no one else got it Prescott  :laugh:
Re: No high beam
« Reply #11 on: November 28, 2015, 11:45:04 PM »
  Oh I got it but it's really dated a ways back.
 I figure anybody who wears suspenders got it.
« Last Edit: November 28, 2015, 11:46:29 PM by Sasquatch Jim »
Offline twodogs
Re: No high beam
« Reply #12 on: November 29, 2015, 08:59:33 AM »
Smoken
1983 Honda CB1100F
2024Triumph 400 Speed x2
Offline ken farr
Re: No high beam
« Reply #13 on: November 29, 2015, 11:14:54 AM »
.....bulb?.....
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
Re: No high beam
« Reply #14 on: November 29, 2015, 11:19:34 AM »
I'd rather fight ...
Sorry, I smoked Camels not Lucky Strikes
    • mysportgear.com
Re: No high beam
« Reply #15 on: November 29, 2015, 05:47:26 PM »
OK the results........loos e wire in the harness going to the headlight from handlebar switch. Now the high beam light and indicator light are coming on....all is good!!
It was Tareyton cigarettes, in the 1960's way, way, before my time, but I heard there is a youtube on the "I'd rather fight than switch" slogan coined by, no doubt, some Madison Avenue executive. They were knee deep in cigarette ad money then, or so I've heard.......now to find my suspenders.
Thanks all  :bow: :bow: :bow:...........Tim
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
