Author Topic: How to refinish stainless head pipes  (Read 4954 times)
Offline dsrdave
« on: December 12, 2015, 06:55:35 PM »
The stainless head pipes on the centauro have become stained.  I'm not sure how to refinish them and don't want to ruin them.  I can blast them with glass, sand or walnut shells.  I thought about buffing with scotch bright also.  Any one have success with something?  Thx, dave.
Re: How to refinish stainless head pipes
« Reply #1 on: December 12, 2015, 07:06:34 PM »
Polish them on a buffing wheel.
Offline guzzista
« Reply #2 on: December 12, 2015, 07:10:38 PM »
On the Staintune stainless exhaust  for my Duc, I used to take it off every couple years and buff it on the metal polish wheel using stainless compound. It would stay shiny and gradually it would turn golden and darken. Buffing it may work without grinding metal off the surface or scratching it  as with any abrasives. Good luck
« Reply #3 on: December 12, 2015, 08:25:39 PM »
Yep. You can buff stainless to look like a pewter dollar. For a while.  :smiley: Don't even think about an abrasive.
Offline nobleswood
« Reply #4 on: December 12, 2015, 08:32:12 PM »
This summer I bought some replacement headers which were in need of some polishing. I found a set of polishing/buffing compounds at Lowe's and bought different cloth wheels for each of compounds I thought I'd use.
It took some time to clean the headers but after I got them on the bike they turned a beautiful pale golden colour after the first ride.
Give it a go unless you're using a wire brush it is hard to bugger these up.
2013 1200 8v Griso
Offline Stevex
« Reply #5 on: December 13, 2015, 09:48:41 AM »
I use Optiglanz, not sure if you can get it in the US.
It's a slightly acidic solution which I wipe or brush onto my CB13's stainless Akrapovic headers.
You can see it removing the tarnish after a few seconds, then rinse off with water.
This is what they look like after a few months on the road:
This is how they look after the Optiglanz treatment:
« Last Edit: December 13, 2015, 09:54:01 AM by Stevex »
Offline rbm
« Reply #6 on: December 13, 2015, 09:58:25 AM »
I followed the following guide when I refinished my stainless headers. They had 25 years of crud on them but came up beautifully after this treatment.  This process requires starting with wet-n-dry sandpaper, which on the surface might be counter-intuitive to a high polished finish but stainless is extremely hard. The key is to remove all prior grit scratches completely when switching grits.
« Last Edit: December 13, 2015, 10:01:35 AM by rbm »
- Robert
2011 Moto Guzzi V7 Racer
« Reply #7 on: December 13, 2015, 10:32:25 AM »
this part is really important.
Once re-installed on the car BEFORE starting the engine, grab your brake cleaner and spray the entire header down with it. Then spray some brake cleaner onto some paper towels and give the header a final wipe down, making sure to wipe everything. You do this because the oils from your hands will cause the header to discolour unevenly, once the engine is started. You do not want this. You want it to turn a nice even bronze after a couple kilometres of use.
Offline Dean Rose
    • Twin Valley Riders
Magnolia '02 EV
Sophia '06 Breva 1100
« Reply #9 on: December 13, 2015, 12:05:09 PM »
I think gold is tarnish resistant.
 :azn:
Offline Rox
  • What's a Goozy?
« Reply #10 on: December 13, 2015, 01:11:41 PM »
I personally love the look of yellowed or darkened stainless. It's a by product of riding.  :bike-037:
02 V11 Lemans
02 V11 Scura
14 Honda CTX1300
07 Yamaha R6
Offline nobleswood
« Reply #11 on: December 13, 2015, 07:33:54 PM »
Chuck,
 i wish I'd known to wash the pipes off with brake fluid before I started the bike up with the new pipes on. I'd cleaned them off well & only handled them with cloth rags, but still they developed uneven blue areas.
Next time !
2013 1200 8v Griso
George_S
« Reply #12 on: December 13, 2015, 07:38:18 PM »
Brake cleaner itself is quite toxic. When heated, brake cleaner containing chlorine produces phosgene gas. I assume it's maybe not harmful if you're riding and moving, but if you're next to it while the bike is stationary and the pipes are heating .....
Offline kirb
« Reply #13 on: December 13, 2015, 09:02:38 PM »
I use Mother's metal polish on the Griso. The griso has the typical 'liver spots' of the shit stainless they use. I do this once a year and they look great for most of the year.
http://www.amazon.com/Mothers-05101-Mag-Aluminum-Polish/dp/B0009H519Y/ref=sr_1_1?ie=UTF8&qid=1450062043&sr=8-1&keywords=mothers+metal+polish
« Reply #14 on: December 14, 2015, 07:05:42 AM »
You have to get it *really* hot to do that, like welding. Just the same, brake cleaner is not nice stuff. Use the usual precautions.. lots of ventilation, etc.
