Author Topic: Oxford Heated Grips: My installation and product review  (Read 7886 times)
Offline willowstreetguzziguy
« on: January 01, 2016, 05:26:20 PM »
First off, THANKS TO EVERYONE who replied when I recently posted questions on:
Which heated grips/ installing them?
How to take off the gas tank and disconnecting the *** elbow connection?
How to remove stock hand grips?
12 Volt outlets?
I LOVE to ride as much as possible. So extending my riding season on my 1200 Sport has been helped with the V-twin cylinders pumping out some nice heat on my legs while the gas tank & wings give good wind protection to my knees & shins. Stelvio hand guards, Laminar lip, and heated vest all add up to being able to "comfortably" enjoy riding down into the 40's.
After your help and careful thought, I asked for and received Oxford Heated Grips for Christmas. So here is my review...
Ordered them online from Revzella - excellent service, came in one day.
Once opened, I realized the "Touring" grips surface seemed hard to the touch and a bit short in length. After some online evaluation, I called Revzilla, explained my situation and I ordered the "Sport" grips which have a slightly softer feel with more of a textured grip surface as well as being slightly longer in length. I also arranged a "free" return ship back of the "Touring" grips. The new ones came in 1 day and they paid the 6% state sales tax, again, on the $89.99 price!
I love the look of the 1200 Sport and that includes the handlebar/dash area. So my intent was to install both the Heated Grips and a 12V / USB outlet as a "clean / stock" appearance. I didn't want to look like Thor on a 5-year adventure around the globe with brackets and gadgets bolted everywhere.
FIRST IMPRESSIONS:
Oxford Heaterz are attractively packaged &  instructions well written.
5-levels of heat with up and down buttons.
Power goes on sleep mode after 2 minutes of inactivity and turns completely off after 5-minutes   of inactivity.
INSTALLATION STEPS  for Heated Grips & 12Volt/USB outlets (took about 8-hours,  never having done it before)
Siphoned out as much gas as possible to lighten the weight of the gas tank.
Took out 5-srews holding the front black grate.
Disconnect 3-gas lines & 1- electrical connection etc. This was the hardest part because of the elbow connection under the gas tank.
I primed and painted the mounting bracket satin black to go with handlebar hardware.
Figured out where to position the grips so the protruding wiring would not interfere with brake & clutch levers as well as the buttons for changing computer readouts and for flashing high beams.
Removed right Stelvio hand guard and small fairing.
Cut & filed down smooth the plastic throttle grip because it had protruding plastic.
Super glued grips into place (no need to wait the recommended 24 hrs., how about 1 minute!!!)
Fished BOTH wiring harnesses above the headlight and back past the steering and along the top frame to the battery. Wired both grips & 12V outlet directly to battery.
Both work! Put all stuff back together. Added gas back into tank and it started up
Went for a test ride after turning grips on 100% high. It was 45 degrees and after only a 4 minute ride, I stopped to wish a riding buddy neighbor Happy New Year. As soon as I shook his hand with my glove on, he commented, "Boy, your hands are warm!" Enough said.
FINAL REVIEW:
Grips start feeling heat in 15 seconds
5-heat settings, 30%, 40%, 50%, 75%, 100%
100% High settinggets HOT even with cold weather gloves. Lowest setting puts slight warmth.
All is first-rate including instructions. Installation looks stock.
Able to reach heat control buttons without taking left hand off of grip.
Grips are a little harder than stock but offer more texture/grip.
Shuts off after 2-minutes of inactivity.
12volt outlet is zip tied on left fairing bracket.
This product ranks a 10 on a 1-10 scale. Could not be happier with the price and the way it warms my hands! THANKS AGAIN FOR YOUR HELP! Here are a few pictures...
« Last Edit: January 01, 2016, 05:29:10 PM by willowstreetguzziguy »
2008 Guzzi 1200 Sport
Re: Oxford Heated Grips: My installation and product review
« Reply #1 on: January 01, 2016, 06:15:09 PM »
Nice job!  Nothing like having warm hands.  There's so many cool mornings in late spring where they are really appreciated.
« Reply #2 on: January 01, 2016, 07:36:07 PM »
 I always thought heated grips were Kinda foo foo..
Until I had some.  :smiley: Thanks for that. Needed them a few times on the Mighty Scura this trip. 30s and 40s when leaving the beach in the morning sux without em.
« Reply #3 on: January 01, 2016, 08:20:25 PM »
I liked the Oxford grips too.  But, that's how I found out that I rarely wrap all my fingers around the grips. Went to elec gloves.
jlburgess
« Reply #4 on: January 02, 2016, 10:22:39 AM »
Nice review!  I had a set installed on the Griso about a 2 years ago and they are holding up well.  I'd have to rate themas a 10 also.  I love the way they were able to mount the controller to the left grip area.
Offline dan_s
    • http://www.world-designs.co.uk/forum/member.php?u=128
« Reply #5 on: January 02, 2016, 01:51:45 PM »
Thanks for the review.
My .02
Installed the "oxford hotgrips premium touring heated grips" on a honda cb500f a few months ago. The interconnectors are low quality, the plastic outer doesnt hold the end bullets properly. There's a wire there straight from the battery +. The rolling bit of the throttle is not smooth on the honda and I had to file it to let the grip onto it. The right grip gets hotter than the left one.
All in all, does what it's supposed to do. Once I find the time I'll connect the power to a wire  after ths main switch, with all respect to the autoswitch in the controller. Hand guards will keep the hands warmer from the outside too.
« Last Edit: January 02, 2016, 01:55:13 PM by dan_s »
Offline rss29
« Reply #6 on: January 02, 2016, 06:22:53 PM »
I think that's caused by the insulation provided by the throttle tube.
Offline dan_s
« Reply #7 on: January 02, 2016, 11:42:22 PM »
Makes sense
« Reply #8 on: January 03, 2016, 09:18:42 AM »
At one time some people recommended wrapping the clutch side bar with tape or some such to help insulate that side a little.  I didn't bother since I figured the grips have a bit extra rubber on that side (but, maybe I am giving the mfg engineer too much credit :)  ).
When I had my grip heaters I never noticed a difference between sides.
« Reply #9 on: January 03, 2016, 01:14:27 PM »
In addition to my original post...I just went for a 40 minute ride in 46° temperatures. I kept the Oxford grips on The highest setting, wearing my winter gloves. I believe the Stelvio hand guards help tremendously in keeping your fingers warm. Your palms definitely get more heat, with the fingers getting about 70%. After getting home took off my gloves and pushed my motorcycle into the garage and in putting my bare hands on the heated grips, they were so hot, I could barely keep my hands on them!! I also really love the textured grip as compared to the original Guzy smoother grips. I probably wouldn't want to ride barehanded with them which I never do anyway.
Online Buckturgidson
« Reply #10 on: February 06, 2019, 08:12:38 AM »
Can you please tell me if you ordered Sport or Touring for the Griso?
Thanks.
"It's not your job to be as confused as Nigel." -Spinal Tap.
"Wagner's music is better than it sounds." -Mark Twain
'24 V100 Mandello, Violetta, bianco polare.
'07 Norge, Rosina, the classy one
