Author Topic: How cool is cool enough  (Read 11945 times)
« on: January 08, 2016, 01:37:50 PM »
 OK , let's try this one more time . The question is how cool enough to adjust valves . The general consensus seems to be room temp , or about 70 degrees , although on a 90 degree day that might be tough  :laugh:
Re: How cool is cool enough
« Reply #1 on: January 08, 2016, 01:41:04 PM »
I say 70F is the goal, but that there's probably at least a 20F swing in both directions that would be fine.
I also say that my garage is attached to my house and has living area above it. So IF I HAVE to set valves on a 90F day, there's a good chance my garage is already only in the 80s at most, and if I leave the door to the house open I can probably get it into the 70s easily enough.
Or we could go to Jay's garage, he's got heat and air.
« Reply #2 on: January 08, 2016, 01:46:59 PM »
If you have a dealer adjust the valves, take it in early, ask them to do the valves after letting the engine cool, like in the afternoon and that should be cool enough to get a good adjustment.
« Reply #3 on: January 08, 2016, 01:53:03 PM »
 :thumb: :grin:
Offline swordds
  • (504)234-9011
« Reply #4 on: January 08, 2016, 04:44:24 PM »
I don't know Jay but I think he should do a scientific study correlating the change in valve clearance settings for each 5 degree change in cylinder head temperature above and below 70 degrees F. And while he is doing that he could take the exhaust pipes off one of his BMWs and put them on his MG and then he could also answer the "quieter motorcycle" question :-). Seriously, I'm just kidding.
2016 V7II Stone
2016 Suzuki TU250X (lost in the great flood of ought 16)
In the future I will strive to tolerate everything except intolerance and to hate nothing except hatred.
Offline mabajada
« Reply #5 on: January 09, 2016, 12:04:39 PM »
.... so adjusting them cold in my 40�F garage is not a good idea? (I just did this as I retorqued the head bolts)
« Last Edit: January 09, 2016, 12:05:56 PM by mabajada »
1974 Eldorado 850 Police
1978 Lemans 850
« Reply #6 on: January 09, 2016, 12:09:49 PM »
  :laugh: Troublemaker  :evil:
Offline JeffOlson
« Reply #7 on: January 09, 2016, 12:21:56 PM »
How much expansion or contraction of the metal parts could there be between 40 degrees F and 90 degrees F? Has anyone ever checked with feeler gauges to see if the ambient temperature makes a perceptible difference?
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
« Reply #8 on: January 09, 2016, 03:25:29 PM »
There is acceptable practice, best practice and unacceptable practice.
There is a gap range and that allows for different temps and such. Stone cold engine is best but that doesn't mean you can't adjust them any other temp such as after sitting for 8 hours and not get a good adjustment or check.
The owner living where they need to adjust the valves and the ambient temps are hovering in the 90s day or night can't get the engine any cooler than that without artificially cooling methods.
Get the engine as cool as ambient temp, it is acceptable or are we all supposed to wait until a cold night to check and adjust valves?
kirby1923
« Reply #9 on: January 09, 2016, 03:50:16 PM »
I believe "cool" just means with the engine not up to normal running temp as in its cool enough to lay your hand on the cylinder heads.  Clearances, (specified by the designer) take into account a wide range of temperatures so as not to be critical.
This subject could rival an oil thread.
As Charlie Brown says "good grief".
« Last Edit: January 09, 2016, 03:52:57 PM by kirby1923 »
« Reply #10 on: January 09, 2016, 03:54:53 PM »
I believe "cool" just means with the engine not up to normal running temp as in its cool enough to lay your hand on the cylinder heads.  (Clearances specified by the designer) take into account a wide range of temperatures so as not to be critical.
 Are you suggesting an oil thread ? We already have the annual ethanol thread going as well as a helmet thread  :laugh: All we need now is a counter steering thread ...
Offline pyoungbl
« Reply #11 on: January 09, 2016, 04:06:45 PM »
The engineers who designed the engine had to deal with the fact that various engine parts are going to expand with heat.  Of course the valves are going to get the most heat and the longer the valve the more expansion.  All the other valve train parts do the same.  It seems to me that it's more important to get an engine down to the ideal temp if you have a long valve train...long valves, long push rods, etc.  If the valves are relatively short and the other components are short you are not going to see much difference in material expansion when compared to other designs.  My Stelvio has pushrods that are about 2" long.  The V7 pushrods are much longer.  Based on that alone, I'd be much more concerned about having the V7 totally cooled than the high cam Stelvio.  If I'm wrong it won't be the first time!
Peter Y.
'13 V7 Special (red/white)
Offline drums4money
« Reply #12 on: January 09, 2016, 04:10:34 PM »
Can any scientographer among us offer any thermal expansion specs?  I'll bet there's a slide rule involved, and that gets above my station in life.  My gut tells me that there's a negligible difference at best for the normal ambient ranges such as 40 - 85 degrees f . . . and that the expansion characteristics of the head alloy and valve material would only be truly & measurably changed above 150deg and below freezing.
I can't see there being an increasing detrimental effect for adjusting valves for every 10 degree delta +/- a 70 degree atmospheric baseline.
I could be wrong - but I'd be interested to see what science offers to satisfy my curiosity.
Old School Audio:
« Reply #13 on: January 09, 2016, 04:15:03 PM »
If I remember,  :rolleyes: I'll look up the coefficient of expansion for various metals in my ancient Machinery's handbook tomorrow. The Kid's coming down to work on his Spot, though, so I'll probably forget..
Offline Vagrant
« Reply #14 on: January 09, 2016, 04:30:03 PM »
just bring back the hydro engine and we can get back to the oil threads.
I'll start it with, had we just used dino 10/40 in the 8 valves would they have failed right away so the Italians would have had to warranty labor in them in the first year OR would they all be running great right now with no failures.
Offline motogman
« Reply #15 on: January 09, 2016, 04:59:19 PM »
How about a tire thread?   :laugh:
« Reply #16 on: January 09, 2016, 07:24:31 PM »
A donut thread
« Reply #17 on: January 09, 2016, 07:29:52 PM »
A donut thread
 Or a donut tire thread  :huh: :rolleyes:
« Reply #18 on: January 09, 2016, 07:40:05 PM »
Gonna have coffee w/that? How bout a smoke?
You still off that stuff Dusty?
« Reply #19 on: January 09, 2016, 07:47:45 PM »
 Coffee , no , and the occasional cigar . Oh wait , are you asking about my silly sense of humor ? :laugh:
Offline RinkRat II
  • Lake Powell AZ
« Reply #20 on: January 09, 2016, 07:57:15 PM »
  The coefficient of expansion on most common metals is determined and measured at 68 degrees F. Different alloys are rated at this temp and there are
specs given by the producers of the material for that expansion. Different standards organizations produce tolerances allowable for their criteria,
ASTM,SAE, ANSI Etc..
     Paul  :boozing:
« Reply #21 on: January 09, 2016, 07:59:04 PM »
When you first came on here posting often, you had just quit coffee.
« Reply #22 on: January 09, 2016, 08:01:05 PM »
     Paul  :boozing:
Yep 40* is too cold
« Reply #23 on: January 09, 2016, 08:04:25 PM »
 I had ? Oh yeah , to help with the cigarette thing . Damn Steve , you have a great memory  :bow:
Offline JeffOlson
« Reply #24 on: January 09, 2016, 08:16:41 PM »
Yep 40* is too cold
People say that, but is it true? How much variation is there in valve clearance between, say, 40 degrees F and 90 degrees F? Does anyone really know?
2018 Vespa GTS 300
2015 Vespa GTS 300
Offline RinkRat II
  • Lake Powell AZ
« Reply #25 on: January 09, 2016, 08:29:28 PM »
  Yes they always know! Just like Santa.  It is a calculation in microinches based on the material used. So the difference between 70 and 90 would be insignificant.
     Paul :boozing:
« Reply #26 on: January 09, 2016, 08:31:00 PM »
If the temperature was that critical between some of the lower temps and the higher temps during different times of year when it comes to adjusting the valves wouldn't there be engines over self destructing themselves because the clearances were either too tight or too loose?
 :Beating_A_Dead_Hors e_by_liviu
« Reply #27 on: January 09, 2016, 08:42:13 PM »
I have been oscillating, vacillating and procrastinating because I need to do the clearances on the Breva. Originally I was waiting for the rocker gaskets to arrive, now it is because it is always hot. :grin:
I must admit, I hear the rapid tappets when I first fire it up, but by the time it has warmed up the tappet noise has gone.  Hardly scientific I know but it does show me that something tightens up when it is hot.
Offline RinkRat II
  • Lake Powell AZ
« Reply #28 on: January 09, 2016, 08:52:20 PM »
  Short answer, Yes. Thats why engineers that design this stuff have to know what the properties of the materials they plan on using are and consult with metallurgists and suppliers to find the best for their application. Thats why many years ago they filled valves with sodium and utilized stainless because of it's stability under temperature fluctuations.
    Paul :boozing:
Offline drums4money
« Reply #29 on: January 09, 2016, 09:14:58 PM »
nail head hit!
From the factory perspective, all concerns are addressed by stating that adjustment be done on a cool 70* engine. I still adjust after the bike has set overnight.  I'm curious nonetheless at what temperatures the expansion/contraction really mean something.
Old School Audio:
