Author Topic: v11 sport throttle body balance nipples  (Read 1903 times)
Offline oranges3
  • "this amp goes to eleven..." Nigel Tufnel, Spinal Tap
« on: January 10, 2016, 03:08:11 PM »
on my v11 cafe sport, the hoses coming off the balance nipples go to a t-fitting and vent to an open line...
all of the reading i have done regarding the plumbing on these bikes says they should be connected to each other, capped off, or the nipples removed and sealed until needed to balance the TB's...
what would the symptoms be if the nipples are not sealed or vented into open air?
2012 ducati diavel
1995 Triumph Speed Triple
1998 Triumph Thunderbird Sport
2004 V11 Cafe Sport
1999 Confederate America GT
2018 Motus MST
2007 griso
1986 kawasaki ninja 600r
183 Honda VT500 Ascot (son's bike)
Offline Moto Fugazzi
    • Griso
Re: v11 sport throttle body balance nipples
« Reply #1 on: January 10, 2016, 03:23:36 PM »
It will suck in extra air, and I believe you're idle will increase a bit. I don't think it affects mid to high RPM's too much, but I could be wrong on that.
I put rubber vacuum nipples on mine and removed the connecting hose.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
2007 Griso Black-Sold
1978 V50 II Blue-Sold
« Reply #2 on: January 10, 2016, 03:38:06 PM »
It will suck in dirt and crud and damage the motor. That is soooo much better that those nasty charcoal canisters.
:violent1:
At least plug it. It will affect idle a bit, but mainly I would worry about the dirt.
« Reply #3 on: January 10, 2016, 05:42:59 PM »
Plug them with rubber caps.  ACE Hardware.
