If the tank leaks after cleaning then think about getting its soldered. Only use a liner IF the tank leaks and you have exhausted all other feasible fixes. Liners are a problem waiting to happen. The application is the simple part. The prep is the hard and most important part. You need to have the tank interior spotless, grease free and etched so the liner can properly adhere. I misapplied liner will cause you lots of heartburn.
Personally, the only one I trust is Caswell Epoxy Gas Tank Sealer.
Do all these liners work on fiberglass as well?
