Author Topic: 1100 Sport Peg Plate Changes  (Read 3158 times)
Enderw88
« on: January 14, 2016, 07:56:58 PM »
Does anyone know which specific year of 1100 sport had this peg plate (porkchop)?
This version notably does not have the extension to the rear to support the subframe.
Re: 1100 Sport Peg Plate Changes
« Reply #1 on: January 14, 2016, 10:01:39 PM »
The pork chops with the 'ole in the middle and rough cast appearance were only used on the Carb models. The 'IE' used the polished pork chops with no hole.
pete
« Reply #2 on: January 14, 2016, 10:25:35 PM »
Yep.  Carb models.  1994-1996.
Offline yogidozer
« Reply #3 on: January 14, 2016, 10:56:38 PM »
and despite what others say about putting a sandwich in the opening, there is a super stable stand that uses the opening, with a removable "pipe" that slips in there
« Reply #4 on: January 15, 2016, 08:19:16 AM »
I really like that rear seat cowl with bum stop!
Any idea who made it ?
Offline twhitaker
« Reply #5 on: January 15, 2016, 08:31:11 AM »
I like the pleasing color of the rocker covers.  :thumb:
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #6 on: January 15, 2016, 05:42:35 PM »
This and the later sport 1100i ones are not direct interchangeable. Because the sporti is 40mm narrower at the top mount. You could put these on the 1100i if you put two 20mm distance pieces between. Then it still doesn't have the mounts for rear frame.
Paul
Daytona 1225, Stelvio 1151
Enderw88
« Reply #7 on: January 16, 2016, 04:18:36 PM »
pete
Perfect, thanks.
