Key fails on my 75T
Topic: Key fails on my 75T (Read 2742 times)
ratguzzi
Key fails on my 75T
January 17, 2016, 03:55:12 PM »
Of all the silly things to fail! I go to start the bike and one of the little teeth falls off my key. So, of course, I can't start the bike. The T uses that special switch that bolts to the frame tab so a quick hole drilled in the dash plate, a toggle switch and "secret" cover, I am good to go!
JB
John Boettcher
Wonder Lake, IL
"I'll quit riding when they pry the handgrips out of my cold dead fingers"
Groover
If it ain't broke, I'll break it.
Re: Key fails on my 75T
Reply #1 on:
January 17, 2016, 06:25:25 PM »
Don't forget to make a copy of that toggle switch
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Antietam Classic Cycle
Happily stuck in the past.
Reply #2 on:
January 17, 2016, 08:23:18 PM »
If you want a proper key switch and housing off of a Convert, I'll send you one.
Charles in Lake Charles
Reply #3 on:
January 17, 2016, 08:34:31 PM »
Some of the universal ignition switches will fit nicely in the holder, but you'll have to put new terminals on the wires. I've done that upgrde to 3 of my older bikes.
TOYS:
1985 Harley FLTC, 1985 K100RT
2001 Lees-ure Lite Camper,
1988 Mercedes 560SL
Reply #4 on:
January 17, 2016, 09:47:05 PM »
With a little bit of modification to the cast switch housing and to the ignition assembly you can get this to fit right in.
http://www.ebay.com/itm/RENAULT-MEGANE-SCENIC-1-MK1-1996-2003-Ignition-Switch-Lock-Barrel-BRAND-NEW-/281283212503?hash=item417dc934d7
I have fit them to V7 Sports and 750S3 bikes.
JoeW
Reply #5 on:
January 17, 2016, 10:24:33 PM »
JB Try this...
http://www.jpcycles.com/product/3700020
Joe Walano
chuck peterson
Reply #6 on:
January 17, 2016, 10:31:36 PM »
Only on a guzzi can you wear out a key ....
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
ratguzzi
Reply #7 on:
January 18, 2016, 07:56:48 AM »
I appreciate the suggestions but I think I have a spare at home. Remember, the switch has two M6 threaded holes that allows it to be bolted to the frame and has a slot for the steering piece so it can lock the steering when the key is in the removal position.
JB
John Boettcher
Wonder Lake, IL
Key fails on my 75T
