Author Topic: Griso shock: Remove and replace  (Read 3058 times)
Offline guzziownr
« on: January 17, 2016, 04:50:43 PM »
My G11 is for sale but I wanted to keep the Stelvio shock and replace it with the stock item.  Originally the shock was changed while the swingarm was off for lubrication, but I knew how to do it the easy way so I am sharing that with you.
The bike:
Stelvio shock in place:
Battery out, airbox access open:
Pretty clean in there, this is a bike with only 10K on the clock:
I pulled the snorkels off the F.I. and unplugged or unclipped any fuses, wires or hoses that got in my way.  Only a couple of each.  Once done I could tip the airbox up without actually removing it to expose the top of the shock.
Unbolt the shock from the bottom first, then undo the top and it comes right out.  The Stelvio item actually fit better!  Assembly is the reverse of disassembly except you do up the bottom of the shock first and then lift the tire and swingarm to locate the top of the shock.  Make sure all your snorkels, hoses, fuses and wires are in place and button it back up.  I estimate an hour if you know what you are doing.  It took me two...
« Last Edit: January 18, 2016, 07:19:35 PM by guzziownr »
Offline lucian
Re: Griso shock: Remove and replace
« Reply #1 on: January 17, 2016, 05:16:34 PM »
Thanks for sharing that. If I may ask, why are you parting ways with the Griso?
« Reply #2 on: January 17, 2016, 05:46:57 PM »
I suspect he's saving that Stelvio shock for another Griso with two more valves and some rollers.
Offline guzziownr
« Reply #3 on: January 17, 2016, 05:47:11 PM »
I will be looking for a low mileage roller tappet bike.  I bought this bike as a stopgap after I sold my '09 and my Eldo spit its u-joint.  Antietam Classic Cycle has my Eldo on the road to recovery so I am liquidating to prepare for my next Griso gambit.
« Last Edit: January 17, 2016, 07:58:48 PM by guzziownr »
Offline guzziownr
« Reply #4 on: January 17, 2016, 06:43:56 PM »
...and the flyscreen, rear rack, semi-rigid luggage, custom seat, G2 throttle, dropped pegs, Stucchi crashbars, dash-mounted Hula girl...
