Author Topic: Difficulty Mating Engine and Gearbox  (Read 11778 times)
Offline smdl
« on: January 26, 2016, 08:32:32 PM »
Hi, folks.
I'm at the point of mating the engine to the gearbox on my 850-T/750S tribute bike, and am running into difficulty.  This is the first bike that I have reassembled with the deep spline (4mm) clutch hub and plates (SD-TEC), and I am finding that it just will not align and go together.  I have the proper clutch alignment tool, and I am able to slide that back into the clutch plate splines (the bolt threads in), so I think everything should be going back together, but it just won't.  I have tried ensuring it is in gear, and have turned the output shaft while trying to mate the two, but still no go.  I suppose I can  disassemble and reassemble the clutch again, and try another time, but thought I would pause and ask if anyone can think of anything else that needs to happen.  I'm not really new to this, having easily assembled both my Eldo and my Stelvio, so I'm a bit surprised that it is being so difficult!
One other thought is that I have heard about certain Eldos having alignment issues between gearbox and engine, and that a 2mm spline clutch hub is recommended for those, but I don't think that this carries through to the engine in this bike.  This engine is from an 850-T, with oil filter.  Also, this bike had a 4mm clutch hub on it already, and Charley Cole replaced it with the same when he rebuilt the gearbox.  So, this engine and gearbox have been successfully mated before, with a 4mm hub in place.
Any advice appreciated, and I can certainly post pics if that would help.
Cheers,
Shaun
« Last Edit: January 26, 2016, 08:46:18 PM by smdl »
'61 Galletto
'74 Eldorado Civilian
'22 V85TT Guardia D'Onore
'24 Stelvio
Offline handyandy
Re: Difficulty Mating Engine and Gearbox
« Reply #1 on: January 26, 2016, 08:53:24 PM »
Make sure both clutch plates are the same. I had a dealer [who will remain nameless] send me a deep and shallow plates.
Offline smdl
« Reply #2 on: January 26, 2016, 08:55:48 PM »
Thanks.  Will check but I am pretty certain that they are the same.  I believe they came together, in the same box, from MG Cycle.
Cheers,
Shaun
'61 Galletto
'24 Stelvio
Offline pehayes
« Reply #3 on: January 26, 2016, 09:06:16 PM »
How about a pic of your alignment tool and the outer face of the friction plates.  With the tool inserted and also with the tool held out separate.
Is there ANY engagement  and it just won't go all the way?  Or will it not insert at all?
Offline smdl
« Reply #4 on: January 26, 2016, 09:15:06 PM »
Hi, Patrick.
It seems that the clutch hub gets just to the point when it starts to engage the friction plates, and then won't go any further.
I'll take some pics tomorrow and post them.
Thanks,
Shaun
'61 Galletto
'24 Stelvio
« Reply #5 on: January 26, 2016, 09:17:25 PM »
Sometimes they are fussy.  I go back & put in tool, snug it to free plates, give the tool a spin one way then the other. Loosen it making sure tool slides in & out freely.    I use an old hub w/spacer and washers to be able to spin it w/the springs are tight like you have the clutch pulled in.
Yep, sometimes w/BIG rubber MALLET      WWAAAKKKKK
Offline Hahnda
    • Scrambler Cycle
« Reply #6 on: January 26, 2016, 09:25:52 PM »
This kind of goes along with what others have said but do you have a spare 4mm hub sitting around to see if that slides in easily?
1949 GTV - 1948 Airone
www.scramblercycle. com
« Reply #7 on: January 26, 2016, 09:30:05 PM »
dumb maybe but the friction plates only go in 1 way, the protruding flange facing to tranny?
Offline smdl
« Reply #8 on: January 26, 2016, 09:42:18 PM »
Thanks, all.
It sounds like Steve's method makes a lot of sense, so I will try that tomorrow night when I get home, and will take some pics at the same time.
Kevin, no, I don't have a spare hub to test with.  I managed to dig out a brand new hub that I knew I had, only to recall that it is for a V11 6-speed.  No help there!
Foto, good thought, but I am aware that these only go one way, and checked carefully when putting them in.  I'll double-check tomorrow, though, just to be sure.
Really appreciate all the excellent input!  No pun intended.
Cheers,
Shaun
« Last Edit: January 26, 2016, 09:43:30 PM by smdl »
'61 Galletto
'24 Stelvio
Offline JoeW
    • The Guzzi Doctor
« Reply #9 on: January 27, 2016, 07:24:59 AM »
When mating the trans I have it in gear. When I get to the point where the hub contacts the clutch, I turn the output shaft using a pliers wrapped in a shop rag. This helps the teeth align.
Joe Walano
kidneb
« Reply #10 on: January 27, 2016, 08:39:23 AM »
Cheers,
Shaun
You will succeed. Mating the two can be a real PITA some times, while other times they just slide together at first try, and I don`t think pictures can be of any help here.
Spinning the tool, as Steve suggests, sounds as a good idea. I use to take out the plugs and rotate the flywheel with a screwdriver through the timing inspection hole while performing the operation.
I don`t know why this is, but when I have been struggling with this myself, I`ve had good luck rotating the flywheel 180 degrees. Hmm,- just a skinny input from here.
         Good luck
Online steven c
« Reply #11 on: January 27, 2016, 08:50:09 AM »
 I have put a little dot of anti-sieze on the end of the spline, then when I pull the gear box back I can see how far off I am on the cultch plate where the anti-sieze touched. Sometimes they slide right on and others just give you a hard time.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
« Reply #12 on: January 27, 2016, 08:56:36 AM »
I do the same thing, but use a worn out driveshaft coupler with Vise-Grips on it to turn the output shaft.
Offline Don G
« Reply #13 on: January 27, 2016, 09:16:08 AM »
The last 4 MM clutch hub that I used was a bastard also, look at the leading edge of the splines, I found mine was dropped and the edge of the splines was battered. A little file work and it went together fine.  DG
Online Perazzimx14
« Reply #14 on: January 27, 2016, 10:56:26 AM »
Drinks usually increases the chances of mating.
« Reply #15 on: January 27, 2016, 11:05:41 AM »
 :smiley: True, true..
Offline smdl
« Reply #16 on: January 27, 2016, 04:40:50 PM »
Okay, following up on this.  I have tried doing as you say, Steve, but I don't find that the plates want to spin when I tighten the tool down.  Probably because of the tension on the tool from tightening the bolt?
I think I am going to dismantle the clutch, and reassemble again, making sure that everything seems to go together as expected.  Will post late once I try it.
Thanks,
Shaun
'61 Galletto
'24 Stelvio
Offline smdl
« Reply #17 on: January 27, 2016, 05:11:38 PM »
By the way, as mentioned in the original post, I did have the gearbox in gear, and was turning the output shaft using the u-joint, but that didn't seem to help.
Thanks again for the great input.  I've brought the wine out to the garage, and am playing romantic music.  Fingers crossed...   :grin:
Shaun
'61 Galletto
'24 Stelvio
« Reply #18 on: January 27, 2016, 05:17:34 PM »
I have a very thick washer w/flat on edge that fits in where the puck goes, then when you tighten the bolt it works like normal disengagement.
Offline normzone
« Reply #19 on: January 27, 2016, 05:17:51 PM »
Well, since you brought it up, be advised that even when you get them to mate they will not reproduce.
« Reply #20 on: January 27, 2016, 05:32:35 PM »
If the rivets come loose they do.
« Reply #21 on: January 27, 2016, 06:00:51 PM »
I made an alignment tool from a scrap of 1/8 Aluminum
It fits in the valley on one side and on the peak on the other, it has two strips of 16 gauge riveted on to line it up on the peak.
« Last Edit: January 27, 2016, 06:02:51 PM by Kiwi_Roy »
Offline smdl
« Reply #22 on: January 27, 2016, 06:46:24 PM »
Thanks, all.  Success!  Once I reassembled the clutch and offered up the gearbox to the engine, it slid home nicely, this time.   :cool:
Only one problem remains, now.  The clutch actuation arm seems really close to the gearbox, and the outer body is recessed into the gearbox housing.  I guess I'll have to go back in and have a look.  Maybe the pressure plate didn't move completely back into normal position?
More investigation needed.
Cheers,
Shaun
'61 Galletto
'24 Stelvio
« Reply #23 on: January 27, 2016, 06:54:59 PM »
Cheers,
Shaun
you didn't forget to put the cup in that the push rod acts on did you?
Offline smdl
« Reply #24 on: January 27, 2016, 07:00:54 PM »
I really don't think so, but I had it in and out so many times today that I am now second-guessing myself.  That would sure make sense, and then I could laugh at myself even more!   :grin:  Will head back out in a few minutes and confirm.
Shaun
'61 Galletto
'24 Stelvio
Offline smdl
« Reply #25 on: January 27, 2016, 07:43:57 PM »
Okay, I have confirmed that the button was indeed in place as it should be.
I haven't disassembled the clutch again yet, but I think everything looks as it should.
This is how the outer body looks:
Any thoughts appreciated.
Cheers,
Shaun
'61 Galletto
'24 Stelvio
Online Wayne Orwig
« Reply #26 on: January 27, 2016, 07:57:00 PM »
That outer body should be close to flush with the back.
Odd.
Did you do anything to the pushrod and bearing that might do that?
I'm guessing no. I would take the clutch bolts back out and see what is going on.
Offline smdl
« Reply #27 on: January 27, 2016, 08:11:03 PM »
Yeah, that's what I thought, too.  No, I reinstalled the gearbox just as it came back from Charley.
I'm done for tonight, but I'll plan to remove the outer body tomorrow night and see what it looks like inside.  I'll also have a look at the clutch again.
Thanks,
Shaun
'61 Galletto
'24 Stelvio
« Reply #28 on: January 27, 2016, 08:12:33 PM »
What clutch plates are installed? S-D Tec? New clutch pushrod?
« Last Edit: January 27, 2016, 08:15:53 PM by Antietam Classic Cycle »
Offline smdl
« Reply #29 on: January 27, 2016, 08:21:27 PM »
Hi, Charlie.
Yes, the plates are SD-TEC, and I don't know about the pushrod.  I suppose that Charley might have replaced it, but I don't recall him mentioning that, and I can't call to check with him.  I'll look back through my emails and see if he mentioned this with his invoice.  He was very good at capturing the work required/done when he worked on an item.
Are these pushrods available in different lengths like they are for the CARC bikes?
Thanks,
Shaun
'61 Galletto
'24 Stelvio
