Author Topic: NGC Alternates to a hand clutch  (Read 5035 times)
Offline Stephen
« on: January 30, 2016, 10:55:53 PM »
I'm looking for an easy pull clutch or foot clutch or?????
A friend has ALS and can't pull his harley clutch.
He mentioned an EZ Pull which reduces pull by 40%.
Any help would be appreciated, he really wants to ride.
Stephen
Carrollton Texas
Christian Motorcyclists Association
2021 V7 Anniversary
2003 Aluminum X
1971 Ambassador
Re: NGC Alternates to a hand clutch
« Reply #1 on: January 30, 2016, 11:00:06 PM »
 A company called Jims sells a centrifugal clutch for Harley Davidson Big Twins .
« Reply #2 on: January 30, 2016, 11:13:20 PM »
  Hmm , now I can't find that clutch , but I am still pretty sure it is Jims that builds it .
« Reply #3 on: January 30, 2016, 11:23:15 PM »
 OK , try this . Rekluse automatic clutch .
« Reply #4 on: January 31, 2016, 12:39:32 AM »
My son has been bitchin about the clutch on his 1200 Harley being really hard to pull in, and he is not really a 97lb weakling. Might do some research on that. Thanks.
« Reply #5 on: January 31, 2016, 08:25:25 AM »
You could always go back to the mousetrap and rocker pedal set-up. And away you go.
Offline drlapo
« Reply #6 on: January 31, 2016, 11:30:57 AM »
Sell the blinged out tractor and buy a Guzzi
Online Perazzimx14
« Reply #7 on: January 31, 2016, 11:56:44 AM »
Convert :thumb:
« Reply #8 on: January 31, 2016, 12:00:18 PM »
 Yep , another Green Acres moment ...
« Reply #9 on: January 31, 2016, 12:06:23 PM »
maybe:
http://disabledmotorcyclerider.com/
Or one of the applications for drag racing?
Todd.
« Reply #10 on: January 31, 2016, 12:11:44 PM »
Convert :thumb:
I'm dealing with this issue for my wife riding a Convert.   I've loosened the clutch lever but her left hand is so weak even that is not comfortable.  Issue on the `77 Convert. is you have to squeeze the clutch lever to find neutral to start the motor, + hold the choke lever, + hit the starter button all at the same time.  Don't remember my `80 Convert. being like this.  Maybe I can bypass the neutral light requirement at a switch?
« Reply #11 on: January 31, 2016, 12:56:58 PM »
Disconnect the wires at the switch in the clutch cable and connect them together. Might need to do the same with sidestand switch circuit as well if that's still hooked up.
Choke lever should stay in the on position by itself, may not even be needed especially in AZ. Just give it two twists of the throttle instead.
Don't forget to hold the (foot) brake if you don't use the clutch. ;-)
« Reply #12 on: January 31, 2016, 01:08:51 PM »
Thanks, Charlie.   Seems both the sidestand and clutch switches are active and the choke used to hold but doesn't any more.  At 3,600' in the winter time in Az. it needs some choke when cold to start.  :azn:  I intend to put my Tow-pac faux trike kit on this Convert. for the Mrs.
« Last Edit: January 31, 2016, 01:12:23 PM by Arizona Wayne »
« Reply #13 on: January 31, 2016, 04:16:51 PM »
There are some excellent auto shifting bikes out there. At some point it isn't always about what you're riding, its that you are riding.
Offline Dilliw
« Reply #14 on: January 31, 2016, 04:57:32 PM »
Yep the dealer near me has at least two '13 Mana GT holdovers with that someone could steal.  Automatic, side cases, and ABS...
George Westbury
Austin, TX
Offline Madtownguzzi
« Reply #15 on: January 31, 2016, 06:03:14 PM »
Randy S.
98 V11 EV
05 HD Electra Glide Classic
Madison, WI
« Reply #16 on: January 31, 2016, 07:13:07 PM »
A really good bike for all around and even touring? Why put a kludge on something else?
