Setting up my LM 1 brake system with a proportioning valve from a same year SP. Has anyone done the swap and want to share thoughts ?. The swap is pretty straightforward asides from the PV taking a bit more space than the original splitter .
Sorry, no experience with this. The same year model SP had a proportioning valve while the LM did not? This reinforces my prejudice that proportioning valves are intended for inattentive touring riders instead of more sporting use.
I'm against proportioning valves, thinking that the original, true purpose of the integrated system is to get both wheels involved in the initial bite of deceleration, with the rider then determining if more force is needed at the front. They work very well that way for me.
Good luck with your conversion, though.
